3 members (Tom Sayles, 1560, aerotaff), 359 guests, and 80 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,757
#215377 08/08/14 07:38 PM
RogerS Offline OP
Hi, all. I need some help with a wiring problem (2003 4/4). A recent loss of all sidelights showed that all my sidelights, front fogs, number plate lights and cigar lighter work off the same fuse. Since I'm about to add a map light to the unused feed from the cigar lighter I'm concerned about overloading the fuse. I thought a good solution would be to separate the cigar lighter (and map light) onto a fuse of their own. Do any of you have any experience/advice of such a job? Any help would be most gratefully received. Thanks.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
RogerS #215385 08/08/14 08:12 PM
The cigar lighter is usually rated at 10amp as it is a heavy load. Your map light would not be anything like that and if it is an LED it would be in micro amps.
You could run a separate fuse but the existing fuse would be fine.
Titus
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
RogerS #215418 08/08/14 10:41 PM
RogerS Offline OP
Thanks, Titus. I know there's an led option for the map light, so perhaps I'll take that route.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
RogerS #215483 09/08/14 11:35 AM
Good idea to move the cigar lighter (oh, err, accessory socket grin2 ) to a separate fused supply anyway Roger.
RogerS #215533 09/08/14 10:27 PM
RogerS Offline OP
Seems like an interesting challenge since the gomog-supplied wiring diagram doesn't quite match the reality of my car - only to be expected, I suppose.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
RogerS #215535 09/08/14 10:39 PM
The unused lead from the cigarette lighter is used by Morgan when they install the optional map light.
RogerS #215599 10/08/14 01:59 PM
RogerS Offline OP
Fitted my Holden chrome map light yesterday using that feed. Still might isolate that circuit onto its own fuse.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
