7 members (DCH, nick w, Simon, Alistair, RedThree, ScotiaSteve, JMcL),
269
61
Topics49,860
Posts837,497
Posts: 508 Likes: 1
Dreiradschubser Talk Morgan Regular
Posts: 508 Likes: 1 |
I have the 2014 urban cooling kit installed. When the ventilator runs, it blows against the driving direction of the car. What about yours, is this a bug in wiring or a feature?
Achim
Posts: 1,461 |
I think that would be all right, as it will click into operation only when the machine is stationary or running at very low speed.
Posts: 1,338 |
The fan is a pusher not a puller?
Wiring such a unit is easy,
But my question is
Where does it wire to,to make it click into operation when stationary or running very slow.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Perhaps it is the back of the engine that needs the extra air flow but it does seem a bit strange. An email to Morgan Customer Support might be in order.
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
I am certain that it is designed to Blow air onto the back of the engine, not suck it through from the front. As mentioned above, it only does it's thing when slow or stationary, so it should be effective this way.
Posts: 508 Likes: 1
I am certain that it is designed to Blow air onto the back of the engine, not suck it through from the front. As mentioned above, it only does it's thing when slow or stationary, so it should be effective this way. so it's a feature and not a bug in my wiring, thanks for confirmation Achim
Posts: 3,562 Likes: 12
Posts: 3,562 Likes: 12 |
Well, in that case, bang goes my good idea to vent the hot air drawn from the cylinders into the footwells for winter heating. Darn.  Unless.... a switch can be wired into the circuit to reverse the polarity?
Posts: 1,338 |
If you switch the wires,you can reverse the direction..but it also depends on the fan blades.. There are 3 types of fans..reversable, pullers & pushers.
Posts: 1,338 |
What type of fan is it?
Driving slow & it pushes the air the opposite direction of the airflow doesnt seem that effective..
But when stationary i guess its ok
Posts: 1,947 |
If you want it to pull perhaps you could reverse the wiring and the fan on the shaft. Why not go the whole hog & mount a really big one on the rear for quiet running when you want to sneak in late engine off, a bit like a Florida air boat. I claim the design rights.
Tim
