4 members (linklaw, Zach, DaveW, RedThree), 296 guests, and 75 robots.
+8Rich 82
Topics49,859
Posts837,497
Jonny72
#217632 21/08/14 04:48 PM
I appear to have an oil leak in an unusual quarter...where the dipstick goes into the engine. Its a Ford sigma 1.6 (2009) car.
Any experience or thoughts?
g
Silver 4/4
GarretJD #217647 21/08/14 06:10 PM
Formerly known as Aldermog
g
A few drops or a lot?
Has the dipstick tube cracked or come lose?
Is the engine over filled with oil?
I have no idea how the dipstic tube is fixed into the block. There could be an "O" ring failure.
Peter J #217660 21/08/14 06:47 PM
It's a few drops but it's ongoing. It's not residue from the stick being put back on the block. I will try to access it and check the O ring
g
Silver 4/4
GarretJD #217721 21/08/14 11:58 PM
on my CVH 1600, the dipstick tube just pushes in to the block, its a tight fit but it goes in as far as the flange and thats it. For oil to leak at this point, would seem to mean a groove in the block or a crack, as there is at least 5" of dipstick in the block. Its not dripping from somewhere above (Rocker Cover?) is it? thinking
Graeme: 2011 +4
GarretJD #217728 22/08/14 06:03 AM
Are you sure the engine is not over filled with oil?
GarretJD #217735 22/08/14 07:25 AM
The dipstick tube on the 1.6 Sigma will easily pull out of the block. It is supported by an upper bracket which normally prevents this. It is a push fit with an "o" ring in the block. This may have come adrift and will allow some oil to drip.
GarretJD #217741 22/08/14 07:33 AM
Increased pressure in the engine block may be causing oil to blow out. May be worth checking the crankcase breather system.
Jays #217743 22/08/14 07:36 AM
Many thanks!
Silver 4/4
Cheshire_David #217744 22/08/14 07:37 AM
I will check this thanks. G
Silver 4/4
