3 members (TBM, Rex_tulips, MJF), 431 guests, and 39 robots.
Adam12 69
+8Rich 68
John V6 53
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,505
Members9,215
Winglad
Lecat Offline OP
I'm still not giving up on my Zetec idling problem viking
Today I found out that the ECU is actually working the way it should, more or less. With the restriction plate fitted only one annoying 'problem' remains; the slow down-winding between gear changes.
The very nice Ford engineer I talked to today (I think he likes my car wink ) told me that the ECU must have a speed sensor signal to establish if the car is actually one the move or stationary. The original Ford solution is a separate sensor for this purpose only - if I understood him correctly. The reason for this arrangement is to minimize the risk of stalling the engine - very 'Ford-ish' if you don't mind my saying so. hide I would rather be in control of this myself!
When checking the system today I found that there is no 'lag' at all in the unwinding sequence if the engine has been allowed to idle for a while. It's behaving perfectly!
Now I have figured that perhaps there could be a work-around; If it was possible to establish which lead transmits the signal from the speed sensor (which ever that is...) and if the nominal 'stationary' value of that signal could be discovered, it would be possible to trick the ECU to stay in the 'stationary' down-winding mode and I would be a much happier man happy3
Any thoughts?
Does anyone know where the ECU is fitted in the -99 4/4? ( I haven't looked yet hide )
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Thomas, I would expect a speed signal to be a pulse from a transducer, with repetition rate related to vehicle speed, rather than a variable steady level.
'09 Gen2 MINI Cooper ragtop
Is this because the idle speed sensor normally fitted to ford gearboxes isn't present with the gearboxes used on morgans ( at least in some cases
Mark - No Longer driving
Rog Offline
I know how infuriating this is Thomas. My Duratec has a similar “feature”. I can’t fix mine either.
Roger
Mine too, a 1999 4/4.
When I commented on it I was told that all Zetecs have that tendency and so just learned to drive the car that way. It would be great if a 'cure' could be found.
Jethro
Connaught Morgan 4/4, Norton Commando, Guzzi V35 Imola, Velocette LE, BMW C1, BMW C650 GT
Mine too.
The revs drop to about 1300 until I bring the car to a halt, when they drop to 900.
I had it explained by a Ford Service engineer, that the main reason was to avoid stalling due to the potential loads put on the engine due to power steering. (Standard on all Fords)
Sound believable, but I am no expert on this (or many other matters)
Doesn't worry me.
Bud
4/4 "Stanley"
Odd on my Roadster they drop like normal car. In fact the idle is so low & so quiet you think it has stalled.
I don't remember my 94 Zetec doing that but then it was chipped
2025 MG ZS EV aka Trigger
Lecat Offline OP
Thank you all smile
Graham: You are probably right.
milligoon: I also find that a bit odd but I don't know... could be though.
Budster: Mine does exactly the same. Try letting it idle for a couple of minutes and see if it changes behaviour.
John V6: Lucky you wink
To begin with I will try to find out more about the wiring loom. Has anybody an idea of where I can find a wiring diagram for a -99 4/4?
I think the Roadster 3.0 has the original matching gearbox so hopefully has the full compliment of engine management?
Formerly known as Aldermog
I wish my V6 did...it used to do as described, but of late it refuses to drop to 800 or so, sits resolutly at 1300.
