7 members (chanteclair, High Hamster, Aeromax51, IcePack, Image, Pyewacket, Tresco), 349 guests, and 34 robots.
John V6 70
DaveW 67
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,012
RedThree
John V6 Offline OP
The cigarette lighter on my 2006 roadster seems very sensitive to the plug position when I try to use my air compressor. It has once fused when the power plug was inserted (ooh aah missues).
Has anyone found a relible alternative unit.
e bay is full of very cheap (AKA risky) Asian stuff & I am not sure I want that in my Mog given it is always on.
2025 MG ZS EV aka Trigger
Mine is similar and would be interested in what you find
cheers
John V6 Offline OP
Cheers. Very impressive.Will review and decide
I replaced my ciggie lighter with a unit that I think came from Maplin- can't find it now on their website, but here's something similar-
http://www.thetoolboxshop.com/0-601-03-panel-mounted-cigarette-lighter-sized-power-socket.html
Gerry.
Gerry
The cigarette/accessory socket can be temperemental and can't be relied on, I still have nightmares from when my sat nav died in Rouen in the rain and in rush hour traffic because it hadn't been charging for hours when It had been plugged in. If you can't source a reliable replacement, and I haven't managed it, one option is to run a direct connection from the battery and plug the accessories into that.
Andrew
'Alice' 2013 Duratec Plus 4. Pearl Blue
When I first took delivery of my S1 Roadster the wires to the cigarette lighter were reversed so that the centre contact was positive. I got through three Sat Nav cables before I worked out what was going on! Easy to put right but expensive on Sat Nav cables.
This is a professional quality product from RS Components who are the leading suppliers to the Electronics Industry throughout Europe.
http://uk.rs-online.com/web/p/automotive-connectors/1222352/?origin=PSF_435717|alt
No affiliation - used them for over 37 yrs.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
In Australia, you get the plug, but not the cigarette lighter. It is illeagal to smoke in a vehicle that has anyone under 16 in it in Western Australia. My tin top has four plugs, 2 in front two in back for fridge.
I fitted a good quality after market double plug directly to the battery with a 10 amp inline fuse.
Graeme: 2011 +4
