7 members (Rog, Plus Four Guy, AlyMatt, Clipper, Image, Winigo, sbarracl), 258 guests, and 86 robots.
+8Rich 76
DaveW 52
Topics49,868
Posts837,634
Moggo
Page 1 of 6 1 2 3 4 5 6
#227003 08/10/14 05:54 PM
Has anyone remapped their 4/4 Sigma yet?
I believe it can be sent away and done by return of post.
It just needs torque or 4th and 5th are pointless. An idea might be to remove those two gears and save weight!
I've changed exhaust and will do induction as soon as I can get the right kit.
I just can't justify the throttle bodies.
Donald - get R.P. to install a 4.11 diff. Makes a huge difference.
Best wishes,
Don.
Donald - Jeremy (WR142LL) had the first remap that Williams did on the Sigma ECU and seems to be very happy with it. Jays also did the TB on his 4/4 Sport but I think you will find he said it wasn't worth it as it made it less manageable lower down & constantly had to be revved hard. I think he thought that going for the 4.1.1 axle would have been better money spent but perhaps he can confirm.
Roger
Pm sent
- Lawrie Mills(Chunkylozza)
Youtube - ChunkyLozza
Pretty correct Roger. The best mod was the change to 4.1:1 diff....it transformed the use of 5th gear in particular and did nor funnily enough affect economy. I'd also fit a decent air filter set up like Cains, together with free flowing sports exhaust followed by a remap.
The throttle bodies sounded glorious but the performance increase does not justify the cost.
Max5 #227165 09/10/14 11:29 AM
R.P. ???
paul #227173 09/10/14 12:02 PM
Originally Posted By paul
R.P. ???
Revolutions Perth (dealer)
Caution my 4.1:1 diff "rings" a bit, but does transform how the car drives.
IcePack #227267 09/10/14 07:41 PM
Unfortunately my english is not well enough, so please explain: what is a 4.1:1 diff / axle?
is it a different gear box at the rear axle?
2015 4/4 "Chaplin" in black and white, usually strolling around at the german north sea shore
Hi Ralf, it just refers to the reduction ratio of the differential gear in the rear axle - for every 4.1 turns of the propellor shaft, the rear axle shafts make a single turn. Morgan fitted several different rear axles with different ratios, and this is the lowest of all of them. It means the cars are relatively low-geared, giving a very sporty feel. The higher ratios give a more relaxed cruise.
For a 4/4, I think the 4.1 : 1 ratio is by far the best...
