https://farm4.staticflickr.com/3889/14978359556_cda323e561_c.jpgcourtesy of warbird
note that the sports exhaust of the stage 1 to 3 upgrade is a totally different sports exhaust to what has previously been offered (which was only a noise difference).
The whole exhaust has been redesigned to be straight thru for stage 1 to 3 and uses s&s derived baffles etc. The exhaust is then put together in the uk.
note when Morgan use the term "exhaust silencer", this is the long section from the clip backwards. This does not include the pipe curve or the catalytic converter.
-the CNC also looks effective.
yes you could go to another fitter and potentially save a few thousand pounds but then...
- you loose value in the car not being a true Morgan system anymore.
- you do not have the correct ecu settings. (the ecu on the m3w is read only so you have to get a whole new ecu system. this may not even pass emissions regulations)
- you have no leg to stand on if the thing goes wrong
- you probably won't be able to race it now, or in the future due to stuffy club regulations or circuit noise control.
- the time spent researching a reputable engineer will have to be considered by me.
