0 members (),
215
91
Topics49,847
Posts837,389
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Superb addition to the "how to's"....thanks.
Richard 1976 4/4 4 Seater
Posts: 881 Likes: 31
Posts: 881 Likes: 31 |
Wonderful thread!...many thanks Dave
Bert & B1800 "Tis well enough to know how much to know; and when to know, not to know, too much."
Posts: 82 Likes: 3
Posts: 82 Likes: 3 |
Really superb information and knowledge you've given us Dave. Many thanks
Colin. --------------
RX450 easier ezchair. 2004 Roadster.CM51ERS.
Posts: 77 |
Another brilliant explanation, Dave. I am thinking of trying this at some future stage but I have some worries about the reamer. You have said that the pilot isn't long enough but is essential to keep the reamer aligned. I think you also mentioned you modified the pilot. Could I ask you to expand on this part of the process as clearly you were successful in reaming the two sides.
David Morgan Plus 4 2005 Jaguar XJ8 1999 LR 110 Station Wagon 2008 Volvo V90 D4 2017
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
David - it was nothing too sophisticated. I took some tape, it was 'chrome' effect but electrical tape would work, and wound it around the end of the pilot until the pilot would just slide into the un-reamered bush. Then I used the tapered sleeve which normally goes over the pilot to keep it centralised on the way through. It's not dissimilar to using a taped dowel to centralise a clutch plate. It would be nice to turn down a metal tube to provide a proper solution, but I don't have the equipment for that!
Posts: 1,502 |
Just a thought, and I may well be completely out of order! The alu protectors are very neat, but if they came loose or partially detached while driving, could they cause any problem with suspension, braking, or steering?
Nigel - The nuts are nyloc and with thread sealer. They can't drop as the lower edge of the guard overlaps the lower tube bracket. They can't lift because that would involve rotation against the gaiter, and there's no space. The U bolt is a perfect (interference) fit around the lower tube. I've had them on the Roadster for about 4 years and they haven't budged. It's no problem checking the nuts when greasing though! My main consideration was allowing enough clearance for the suspension on full rebound, and for that reason they are a bit shorter than I would like.
Posts: 517 |
Dave- Why do you fit the alloy shields when you have such good fitting lower spring gaiters?
Titus
2007 +4 4 seater 2017 Mini Cooper 2007 VW Camper 1996 Honda TRX300 2012 Husqvarna 216
It's my OCD Titus. Belt and braces, and braces........
Posts: 77 |
Thanks. That makes sense to me.
