0 members (), 267 guests, and 81 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 8 of 11 1 2 6 7 8 9 10 11
Superb addition to the "how to's"....thanks.
Wonderful thread!...many thanks Dave
Bert & B1800
Really superb information and knowledge you've given us Dave. Many thanks
Colin.
RX450 easier ezchair.
2004 Roadster.CM51ERS.
Another brilliant explanation, Dave. I am thinking of trying this at some future stage but I have some worries about the reamer. You have said that the pilot isn't long enough but is essential to keep the reamer aligned. I think you also mentioned you modified the pilot. Could I ask you to expand on this part of the process as clearly you were successful in reaming the two sides.
David
Morgan Plus 4 2005
Jaguar XJ8 1999
LR 110 Station Wagon 2008
Volvo V90 D4 2017
DaveW Offline OP
David - it was nothing too sophisticated. I took some tape, it was 'chrome' effect but electrical tape would work, and wound it around the end of the pilot until the pilot would just slide into the un-reamered bush. Then I used the tapered sleeve which normally goes over the pilot to keep it centralised on the way through. It's not dissimilar to using a taped dowel to centralise a clutch plate. It would be nice to turn down a metal tube to provide a proper solution, but I don't have the equipment for that!
Just a thought, and I may well be completely out of order! The alu protectors are very neat, but if they came loose or partially detached while driving, could they cause any problem with suspension, braking, or steering?
DaveW Offline OP
Nigel - The nuts are nyloc and with thread sealer. They can't drop as the lower edge of the guard overlaps the lower tube bracket. They can't lift because that would involve rotation against the gaiter, and there's no space. The U bolt is a perfect (interference) fit around the lower tube. I've had them on the Roadster for about 4 years and they haven't budged. It's no problem checking the nuts when greasing though! My main consideration was allowing enough clearance for the suspension on full rebound, and for that reason they are a bit shorter than I would like. thumbs
Dave- Why do you fit the alloy shields when you have such good fitting lower spring gaiters?
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
DaveW Offline OP
It's my OCD Titus. Belt and braces, and braces........ grin2
Thanks. That makes sense to me.
David
Morgan Plus 4 2005
Jaguar XJ8 1999
Volvo V90 D4 2017
