2 members (+8Rich, Saxonian), 381 guests, and 50 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
Page 5 of 5 1 2 3 4 5
I would like to come back to the beginning of this thread. Two days ago I also changed the bulbs in the sidelights against LEDs. The second photo shows the difference. The LEDs are from Ebay €3,80 a pair including postage.
Keep mogging,
Christian
New LED and old bulb (sorry for the bad photoquality)
The Difference. The LED is the whiter light on the right side of the picture.
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
Peter J Offline OP
Formerly known as Aldermog
They do make a big difference!
SBM Offline
Enough difference to perhaps make that essential difference between being seen & being ignored..
Well it's taken a while. My angel eyes have been resting in the garage all year, but now, today I took the plunge. First I fitted some 2 pin plugs for the sidelamp units so that I can switch back easily if needed.
As said earlier, slightly fiddly to fit with three small screws per side to fit the lamp unit to the inner bezel, plus one more to affix to the car. Note here that I have previously fitted a strip of neoprene around the inner bezel, because it whistles at speed, and this reduces the whistling, as air passes between the outer bezel and inner, um, bezel.
When the outer bezel is clipped on, it barely locates because the brackets are so small. So here is some 4mm neoprene around the lower edge and across the screw hole. The purpose of this is to pull the bezel down so it fits tighter against the brackets at the top,
Fitted and 'off'.
Fitted and 'on'. Taken in the dark, but the flash spoils the effect.
Looks smart....I have been wondering what do do with my sealed beam units. I notice Librands now offer something similar.
Peter J Offline OP
I fitted a pair to Aldermog and they will migrate to George.
I took this tonight in the dark - might give a better impression.
Saw this post which is very interesting as have had issues with night driving last month , am getting some uprated bulbs along with the major upgrades being carried out ! Will see what difference more powerful bulbs makes to dipped beams !
