Morgan Aero 8
4 members (Ulfulf, JMcL, Bishmog, 1854sailor), 316 guests, and 9 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,034
RedThree
Peter J Offline OP
Formerly known as Aldermog
Yes it does!!
Fitted the angel lights and I get a flashing display in the speedo "Bulb Failure"!!
It doesn't like the LED sidelights!
Anyone know how to fool the computer?
Black Rat
Black Rat
I believe you need to fit a resistor in the circuit, I'm sure someone will know exactly what and where.
Keith
2013 narrow bodied + 4 Ruby.
Peter J Offline OP
I think you are correct, where is easy, but what needs someone who understands these electron things...!
The standardside light is 1.5w, I think. Obviousy the LEDS are less as the "brain" sees an open circuit.
The handbook made no mention of the bulb failure indicator!
Black Rat
Black Rat
Keith
Ohms law and the power triangle might help calculate the resistance required?
V W
A R A V
Hope that helps and is not teaching you to suck eggs
BR Colin
The system scrambled it a bit was trying to write
V
A R
A V
Hope that's clearer
BR Colin
Side lights are normally 5w
You'll need a 3w resistor. About 48-68 ohm
Or find a friendly bmw centre to reprogram your ecu to the led resistance.
Putting load resistors sort of negates the low power Useage of LEDS as you are still consuming the same power as a normal filament bulb.
Mark - No Longer driving
Peter J Offline OP
Thanks Mark, I'll see what I can find in Maplin.
You are right, putting a load resistor in parallel does negate the low power drain of LEDs but I'm more concerned about the visibility of the parked car.
I've also discovered that like a BMW the parking lights are controlled by the indicator stalk, you can't just leave the car with the side lights on. You have to select a side to illuminate!
Electronically it is more of a BMW than a Morgan. I don't mean that in a negative way, either.
No, you're right. Complication aside I've had no electrical problems on my S3 Aero so thank you BMW and well done Morgan (although I find the cruise control works a bit oddly and tend not to use it...)
When I fitted some DRL style headlamps I used a Scotchlock connector to splice into the sidelight wire to connect the LED's. I had to leave the original sidelight bulb in situ and tucked it up behind the headlight to fool the computer and avoid a bulb failure message on the dash display. Keith's solution, however, seems rather more professional and still cost effective.
Bren
Plus 8
Rhodium Silver with black leather
Caterham 620s
