9 members (RichardV6, cerealsurfer, bmgermany, britmog, Morganmike, Gordon D, TBM, Zach, IcePack), 305 guests, and 67 robots.
+8Rich 75
Topics49,861
Posts837,533
Jonny72
#238190 05/12/14 12:48 AM
Read T Offline OP
Here's a question for y'all!
1960 Morgan +4, TR3 Engine, Press on flywheel ring gear
I recently replaced the starter with a gear reduction version while I had the engine out for a rebuilt. The new starter is from Morgan Spares. Before I call them and sound like an idiot smile I figured I'd ask here. The new Starter makes a clank and doesn't seem to be engaging with the flywheel, crank/fan doesn't spin either. The starter that came off of the engine was a 10 tooth (i'm not sure if it was original), the new one is a 9 tooth. The engine builders said that the 9 tooth is the correct starter for the press on flywheel.
Can anyone confirm this? Hopefully it's just the wrong starter and I didn't somehow put the flywheel in backwards grin2
I haven't tried re-installing the old starter yet, but could do this just to make sure the problem is starter-related. I've just kept busy bolting everything else back on.
Thanks!!!
Read
1960 Morgan +4 4 seater
1997 Nissan 240sx S14
2011 Nissan 370Z
2009 Triumph Street Triple
Has the new flywheel changed the throw required on the starter? It only needs to change by 5-8 mil
Graeme: 2011 +4
Read T Offline OP
it's the same flywheel, just had the clutch facing resurfaced, so it shouldn't have?
2011 Nissan 370Z
Read T Offline OP
Turns out the solenoid had just died. The bendix was extending, but not spinning. bypassed the fire-wall mounted solenoid to use the gear-reduction starter solenoid and it's working great.
2011 Nissan 370Z
thumbs
Graeme: 2011 +4
