7 members (John Winn, Ian Wegg, Plus Four Guy, linklaw, AndyGoff, MartO, Image), 298 guests, and 53 robots.
+8Rich 82
Topics49,859
Posts837,497
Jonny72
#88553 16/04/12 02:02 AM
Mark E Offline OP
My 1958 plus 4 moss box oil leak has got to a point where it is time to pull the gearbox to replace seals etc. Could someone please let me know the best way to remove the gearbox from the car.
Mark E #88667 16/04/12 08:11 PM
@ Mark, it's very easy, remove the seats, steeringwheel, carpets and the gearbox & propshaft cover.
Put a thick piece of wood under the magnesium belhousing.
Remove the 4 propshaftbolts, handbrakecable and 6 gearboxbolts.
Put your jack under the gearbox, and work it loose.
My box was leaking at the front, it needed just a new oilseal.
If your box is leaking at the back, look at Gomog.com
Good luck.
Don't forget the paper gasket on the front when you put it back, otherwise you may get a leak from the front of the layshaft.
'65 +4 four seater
Mark E #240149 14/12/14 07:51 PM
Resurrecting an older thread, any tips on how to get the input shaft muff-coupling unhooked?
Just re-installed my engine-transmission to find the gearbox is spewing like an angry camel after a dentist visit.
1960 Morgan +4 4 seater
1997 Nissan 240sx S14
2011 Nissan 370Z
2009 Triumph Street Triple
Mark E #240154 14/12/14 08:34 PM
Ray Offline
Be carefull of the pin under the torque tube that operates the clutch thrust .
Mark E #240370 15/12/14 10:00 PM
Good point, and obviously don't disengage the clutch when the transmission is disconnected. Now... about that darn muff coupling
2011 Nissan 370Z
Mark E #241528 21/12/14 08:13 PM
Got the coupling off with a lot of heat, prying, and tapping the input shaft with a rubber mallet. Darn thing was rusted on there pretty well.
Now comes the fun task of stabbing the gearbox back in with the engine already in place.
2011 Nissan 370Z
Mark E #455276 15/06/17 11:28 AM
Hi Ive just taken our plus 4 1958 gearbox out and wondered if anyone had advice on curing the following symptoms
Engine running in neutral gearbox noise
Clutch in then no noise
Car running in gear and if engine put under strain a noise like frying onions either going up hill or accelerating any idea what this may be ?
Front shaft bearings with the 'bearing outrigger had steel swarf from somewhere didn't appear to be in the main gearbox
(bearing outrigger is aluminium bearings feel ok)
see flicker photos see photos here
Triumph Herald 1969 13/60
Morris 1970
Mark E #455302 15/06/17 01:16 PM
Black Rat
Black Rat
I take it's not the clutch thrust race ?
Keith
2013 narrow bodied + 4 Ruby.
Mark E #455309 15/06/17 01:36 PM
Inside the bellhousing is a small 'prop-like' shaft; called the quill shaft. this is connected to the front of the gearbox (over the toothed splined shaft shown is photo) and the front of the quilt shaft is a 1 inch or so diameter 'rod' that does through the clutch and teeth connect it to the clutch.
This quill shaft is often 'stuck' to gearbox and comes out with box; good if it does.
You must be careful not to allow weight of gearbox to drop down with quill shaft still engaged at both ends - it can quite easily bend the clutch bar-end
