Topics49,838
Posts837,296
Posts: 7 |
My 1958 plus 4 moss box oil leak has got to a point where it is time to pull the gearbox to replace seals etc. Could someone please let me know the best way to remove the gearbox from the car.
Posts: 218 |
@ Mark, it's very easy, remove the seats, steeringwheel, carpets and the gearbox & propshaft cover. Put a thick piece of wood under the magnesium belhousing. Remove the 4 propshaftbolts, handbrakecable and 6 gearboxbolts. Put your jack under the gearbox, and work it loose. My box was leaking at the front, it needed just a new oilseal.   If your box is leaking at the back, look at Gomog.com Good luck.
Posts: 167 |
Don't forget the paper gasket on the front when you put it back, otherwise you may get a leak from the front of the layshaft.
'65 +4 four seater
Posts: 142 |
Resurrecting an older thread, any tips on how to get the input shaft muff-coupling unhooked?
Just re-installed my engine-transmission to find the gearbox is spewing like an angry camel after a dentist visit.
1960 Morgan +4 4 seater 1997 Nissan 240sx S14 2011 Nissan 370Z 2009 Triumph Street Triple
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Be carefull of the pin under the torque tube that operates the clutch thrust .
Posts: 142 |
Good point, and obviously don't disengage the clutch when the transmission is disconnected. Now... about that darn muff coupling
Posts: 142 |
Got the coupling off with a lot of heat, prying, and tapping the input shaft with a rubber mallet. Darn thing was rusted on there pretty well.
Now comes the fun task of stabbing the gearbox back in with the engine already in place.
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
Hi Ive just taken our plus 4 1958 gearbox out and wondered if anyone had advice on curing the following symptoms Engine running in neutral gearbox noise Clutch in then no noise Car running in gear and if engine put under strain a noise like frying onions either going up hill or accelerating any idea what this may be ? Front shaft bearings with the 'bearing outrigger had steel swarf from somewhere didn't appear to be in the main gearbox (bearing outrigger is aluminium bearings feel ok) see flicker photos see photos here
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
I take it's not the clutch thrust race ?
Posts: 44 |
Inside the bellhousing is a small 'prop-like' shaft; called the quill shaft. this is connected to the front of the gearbox (over the toothed splined shaft shown is photo) and the front of the quilt shaft is a 1 inch or so diameter 'rod' that does through the clutch and teeth connect it to the clutch.
This quill shaft is often 'stuck' to gearbox and comes out with box; good if it does. You must be careful not to allow weight of gearbox to drop down with quill shaft still engaged at both ends - it can quite easily bend the clutch bar-end
