3 members (RichardV6, RedThree, TBM), 314 guests, and 52 robots.
Topics49,846
Posts837,382
Page 1 of 4 1 2 3 4
#242848 29/12/14 05:02 PM
Kaou Offline OP
Hello all,
I just pulled out of the garage my lovely Three Wheeler for a ride after few months.
Low batt, then a bit slow to fire in this cold weather...eventually it started and I took place for a short tour.
The engine struggled a bit to rev' up but I thought it is still cold and didn't run for some time so I continued, then I saw the engine warning light coming up when I release the throttle above 2500rpm.
The car was running smooth and sounded good, so I decided to continue driving it...
The other issue I noted was the engine being "choked" if I kick down the throttle at reasonably low rev.
I am thinking about a lambda sensor issue, what do you think ?
Any similar problem ?
The ride was around 10 minutes, so I may need to run it longer ?
When you say "cold weather" would it be cold enough to ice up any of the inlet system? It happened to me a couple of years back when I took the Three Wheeler out on New Years day.
I don't think Lambda sensors normally give too much trouble.
Kaou Offline OP
Thank you for sharing the feedback PaulJ.
It was -6°C so it could ice something yes...
I found some thread on the forum talking about a faulty ECU showing engine warning light when the driver stop accelerating.
I will try to acces the diagnostic with ProTune II tomorrow.
could be old fuel.do you use 95 or98?Once,after filling wiv 95,warning light came on,& some uneven running.I drained tank& put in 98.after 5km,light went out.always use 98 now,though problem could hav been poor fuel.
I'm just returning from a short roundtrip with the M3W.
It's -4 degrees and the starting process was time consuming. Took 3 longer attemts to get the engine running. I was already afraid the battery may not have enough capacity, but the battery was strong. No problem with the oil or cold air. I use 98 oktan petrol.
Was fun to drive but on the slippery roads I had to be careful to keep the rear wheel on track...
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Kaou Offline OP
Thanks you guys for sharing, tomorrow I will run it again to see... On a longer attempt.
I run on 98...
Mine is light since 10000 km
I ll try to Switch of when i ll go to my dealer
But the MTW run very Well
You ran the MTW for 10.000km without going to the dealer/ having no problems???
Hannes
Yes i do all the services by myself
No problem
I changed oil twice ( bevel box And engine )
Kaou Offline OP
I extracted the diagnostic from the car with ProTune II, it may interest a number of people, eventually helps me to understand what's wrong.
Page 1 of 4 1 2 3 4
