0 members (),
214
90
Topics49,847
Posts837,389
Posts: 528 |
I know that some of the dealers offer a service where they will apply a vinyl type covering on the vulnerable parts of the car (eg front, runner boards, front rear wings etc). When I inquired it was quite an expensive option. Does anybody know where you can get the pre-cut panels for DIY? Has anyone done it DIY? Is it difficult?
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
Might be easiest to go to one of the companies that specialise in vinyl wraps and see what they can do for you. Getting vinyl to lay over compound curves without wrinkles is not an easy job at all.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Three Ms do a spray on type. there was a thread on it recently.
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
Weighed against the value of the car and the cost of respraying stone-chipped panels, it is not really so expensive as a dealer-fit option and it is highly effective. Don.
Posts: 6,538 |
Does the covering mask/hide small chips etc?
Neil
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
The 3M is a spray version of vinyl wrap type coverings. There is a video of it on YouTube showing it being applied to a car. Search YouTube, I did as I am considering trying it. Video is good in that it shows what to do and what you will see during application and what to look for.. Any chips need repair first and you spray it over a waxed finish. It peels off so no disaster if it goes wrong.
Posts: 112 |
Hi, I have fitted a couple of kits to trads, not easy patience is the key word! The defendal kits are available from RPM/Revolutions at Perth Well worth doing. David
,,BSA Goldstar,Honda CB1100R. Jaguar FTypeS Porsche Cayman S
Posts: 463 |
Check out this home video from You Tube of the 3M Defender spray-on product https://www.youtube.com/watch?v=_7IlTIgUGBA
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Might be easiest to go to one of the companies that specialise in vinyl wraps and see what they can do for you. Getting vinyl to lay over compound curves without wrinkles is not an easy job at all. This is an excellent idea. A local vinyl wrapping firm fitted a good quality material (Defendall springs to mind) for a friend for around £200. Only sloth on my part stops me from going down this route. The better firms have fitters with accreditation from manufacturers I think.
Posts: 27 Likes: 1
Posts: 27 Likes: 1 |
Morgan now 6 years old, vinyl applied when new by dealer. Very effective, stops all those nasty stone chips which I used to suffer from on my previous Morgan. Agree with Don (Max5) relatively cheaper than respray.
Eddie
