Topics49,859
Posts837,502
Posts: 163 |
Torsten
plus 4 MY 2014
Posts: 1,502 |
If I may make a suggestion. The nyloc nut on the outside looks a little unfinished. You could alternatively use a s/s dome nut, which would need a little Loctite to fix it in place.
Nigel
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
The current cars have different rubber "channels" which the sidescreens fit into -- talk to your local dealer - they can supply them -- I got mine for my 2009 plus4 from Brands Hatch Morgan about £20 for the pair, I think! "Does what it says on the tin" stops the sidescreens "bowing" out.
Cheers!
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Tarka came with these new channel sections. They work well.
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Cheers! Any chance of a photo and a description of what is involved in fitting these? Thanks.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
take the old off stick the new on, depending on length you may have to creatively trim the lower portion to follow the curve of the window frame
The adhesive strip on the rear may not hold it on the curve otherwise - ensure paint work is thoroughly cleaned before sticking in place - ie all common sense stuff, measure 83 times cut and fit once sort of thing.
Posts: 14,009 |
I've fitted these to my Roadster. You may need to carefully trim the flange that grips the front of the side screen to allow the door to close correctly.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
With my car the side screen sits ok. No gap opens. The hood edge that comes over the top of the side screen is what comes free. There is a Velcro strip on the inner flap to hold it but this won't keep it there at motorway speeds, and the hood comes away leaving a gap above the side screen. I need to upgrade the Velcro to something stronger, so small, powerfull magnets would possibly work, the narrow size of the side screen aluminium frame restricts what could be used but not impossible, even a small plate strategically placed could be added. I will try magnets as they are not expensive.
