0 members (),
269
SORN
New
Topics48,368
Posts813,421
Members9,215
Posts: 158 |
I tried to get the front wheels off (for the first time) yesterday. The are spoked wheels with the hex center nut (without the ears). I have the spanner tool but try as I might with a mallet, the nut will not budge.
Any thoughts?
Silver 4/4
Posts: 5,233 Likes: 126
Posts: 5,233 Likes: 126 |
Have you checked which direction they undo? RHS (off side in UK) undo clockwise. LHS (near side) undo counter clockwise.
Also, how old is the car? The centre nuts tighten as you drive. When worn, they can tighten to the point where they are tough to remove. Fixed this on our old (1985) car by fitting new hex centre nuts.
Posts: 11,870 Likes: 138
Posts: 11,870 Likes: 138 |
Sorry to ask, but I must check the obvious - you are hitting them in the correct direction, aren't you? The wheel nuts on the right hand side of the car are left hand threads, the ones on the left are right hand threads.
Posts: 1,639 Likes: 20
Posts: 1,639 Likes: 20 |
Personally I never hit mine with a mallet as you can easily bruise the brass spinner. I carry a homemade extended handle for the spanner. You may also need somebody sat in the car with their foot on the brake pedal to stop the wheel turning if it is really tight.
Roger 2011 Plus 4
Posts: 35,796 Likes: 474
Posts: 35,796 Likes: 474 |
Get a 2' x 1/2" round bar welded onto the spanner and you won't need to worry about distorting anything and the added leverage makes it an easy job.
Posts: 8,014 |
A no9 rawhide hammer it fits under the seat .
Posts: 3,383 Likes: 13
Posts: 3,383 Likes: 13 |
Any thoughts?
G If they are that tight check the direction of turn and then turn the steering on lock so your direction of turn is furthest out (think protecting your leg and bodywork, put on the spanner so its as close to parallel to the ground as you can get it and put your foot on the spanner, push, don't jump, on the spanner with a steady and increasing force and you might find it turns. I have had some so tight it takes someone in the car applying the brake to stop the wheel turning. Re the comment about welding an extension to the spanner if you don't have access to welding gear you can, assuming you have some spare metal, also extend it by drilling a couple of holes and bolting on an extension, as the actress said to the bishop its amazing what a few extra inches can do! Should have added that I have done the bolt on extension to mine for roadside use (I have the Mulfab spanner at home on the garage wall), also if you put the MMC spanner in a vice and give it a couple of degrees 'tweak' it moves the end for your foot away from the tyre and makes it much simpler to use, I only put the nuts and bolts in finger tight so it can go back in the toolbox together in a few seconds.
Get a 2' x 1/2" round bar welded onto the spanner and you won't need to worry about distorting anything and the added leverage makes it an easy job. Or buy a spanner from Peter and Simon at MulFab? http://www.mulfab.co.uk/our-products/6/tools
Posts: 14,009 |
Carefully heat up the hub nuts with a heat gun which might help them ease off.
Homemade spanner extender (stand on). Disassembles and stows under the seat. The mallet stay at home!
Roger 2011 Plus 4
