6 members (BillHart, Themorganeer, Chris Cosher, MogOnTheMove, Ubiquitous, GrumpyPa), 295 guests, and 42 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,325
Members9,215
Page 3 of 4 1 2 3 4
At Mog MMX in Buxton, our 1985 car was the DonMog entry in the pitstop challenge. I swapped my shiny new centre nuts back to the old ones on the front to save the chrome from a number of wheel swaps. Arriving at Buxton and finding that the ladies team (The Bakewell Tarts) were up first, I quietly set to to loosen the nuts a tad. Could I shift them - I could not. The (then) 25 year old nuts had self tightened on the drive up to Buxton to the point where it took a fair wallop to shift them. Later in the day, I refitted my shiny new nuts and no further issues.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Posting Desperado
Posting Desperado
Forgot! when you put Molylube on your splines before you put the wire wheel back on DONT wipe the grease on along the groove use an ice lolly stick and go around it NOT along it . They are razor sharp . You only splice your finger once but you scream like hell for ages. By is it painful. drive
Jack yes very painfull. I learnt the hard way. Hence the paint brush.
2025 MG ZS EV aka Trigger
If the splines are razor sharp then they're badly worn.
1972 4/4 2 Seater
Posting Desperado
Posting Desperado
Thanks . I will be checking them out once the weather picks up .Sunny and blue sky but cold enough for 2 pair today. snow
Here is a photo of my garage longarm.
Harald
Thats an impressive Long Arm!
Neil
Yes, there is a risk of lifting the car off the jack stand, so in case the wheel nuts are very tight, the car should be on its wheels.
Harald
I have a 900mm breaker bar to remove the nuts and use a 600mm breaker bar to tighten the nuts and use a socket purchased from Ledgerwoods.
The setup works well.
Ian
Another trick, and worth a try, is to whack the nut with a rubber mallet while at the same time applying pressure to the spanner extension by standing on it. As mentioned previously, don’t jump on the spanner just apply a constant pressure. It's a bit of a balancing act and sounds daft but works in most cases.
Jeff
2009 Black & Tan +4
Page 3 of 4 1 2 3 4
