SORN
New
Topics48,370
Posts813,482
Members9,215
Posts: 158 |
Folks,
I have a 2009 4/4. Standard tyres and wheels. The only think really annoying me is the calibration of the speedo which is reading 15kph - 20kph faster than GPS reading. The current celebration on the clock setting states 21200.
Two questions:
1. Could anyone tell me the correct setting or setting options to try 2. Could anyone tell me how I change the current setting
Sincere thanks
Garret Ireland (Six Nations winners..again)
Silver 4/4
Posts: 3,383 Likes: 13
Posts: 3,383 Likes: 13 |
Folks,
Two questions:
Sincere thanks
Garret
Hi Garret Yes I can, but as you have mentioned the rugby Bugger Off!
Folks,
Two questions:
Sincere thanks
Garret
Hi Garret Yes I can, but as you have mentioned the rugby Bugger Off! And because I am a soft touch here you go http://www.gomog.com/allmorgan/VDOCALIBRATION.htmlAmazing games and well done you guys,
There is a code number you need and I am sure one of these guys can let you know, otherwise it's a call to the MMC I am afraid.
Posts: 81 |
To enter the set up / programming mode, perform the following action. Keep the small button for resetting the trip counters / trip meter under the dashboard pressed and then switch on the ignition. Then in the speedometer display the number 021200 is displayed.
Now the first digit starts to flash. Always the number that flashes can be adjusted by pressing the button again. The flash is automatically moved from front to back.
The optimized step number for a more coherent speedometer is 022800.
If you have set the last digit, just wait, the display automatically returns to the kph indicator.
4/4 sport
Posts: 158 |
Silver 4/4
Posts: 158 |
Thanks all for the advice. Rgds G
Silver 4/4
