8 members (MJF, B3MOG, sbarracl, Bishmog, WR142LLJPN, ScotiaSteve, Alan Patterson, Franky),
364
100
Topics49,868
Posts837,639
Posts: 688 |
In the Audi Bi-Turbo you can switch the exhaust sound to " dynamic"- " which is nice" We could add a couple of toggles to the 4/4 that give rear/ side and four pot/ V8 choice. Then fit cup holders. Then........
Porsche 981 Spyder V8 Speedster ( 5 years) 4/4 Competition spec (5 years) 4/4 4str Kent ( 10 years)
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Insane mode would be good..happens in my head quite regularly..! You have to stop talking to Stringer, he is leading you astray...
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Perhaps "Q Section" should be asked to provide a system.... Loud mode or Stealth mode options... All at a press of a button..... Pedestrians could then either be Shaken or stirred!
Posts: 651 Likes: 12
Posts: 651 Likes: 12 |
Perhaps "Q Section" should be asked to provide a system.... Loud mode or Stealth mode options... All at a press of a button..... Pedestrians could then either be Shaken or stirred! That is indeed possible. Electric exhaust cutouts are available from several sources. Then you can activate the side pipes by pressing a button. Harald
Harald +4 4-seater 2008 Squadron Blue
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
You would look a bit odd with a side & a rear exhaust.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
You would look a bit odd with a side & a rear exhaust. On damp roads you might spin around like a catherine wheel.
+8 4.8
Come on gents.....Q would make the pipes not in use move up out of sight! Perhaps have covers move to hide them too. What I want are his revolving number plates......
Posts: 40 |
Did this to my +8 last year as a diy. Instead of cutting the running board I angled the 90 degree bend so it pointed down a bit so as to just clear under the edge of the board. I then marked it with a vertical circumference line and cut the pipe. As the cut end is vertical it looks like the pipe is coming out horizontally. A benefit of the arrangement is that the gases come out with a downward direction so they don't burn bystander ankles, the mog also now sweeps the garage as I reverse out!
G Walker 1983 +8, 1933 singer 9 2022 MG ZS (electric)
The +8 leaf blower. I like that idea
Posts: 3,825 Likes: 69
Posts: 3,825 Likes: 69 |
Any chance of a picture? Nick
