7 members (High Hamster, KLASG, JohnHarris, Graham, G4FUJ, John Winn, Zach, Sir Percival),
226
95
Topics49,872
Posts837,695
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
My plus8 has overriders and a standard badgebar. The bar fills he gap between the overriders. To put spots on it would mask off the grill reducing airflow to rhe rad, I have arranged badges on it to minimise this. I have foglights on brackets on the wings and they are solid....no issues. I have never used them! Even at night, as the light is not long distance like spots. I have nightbreaker bulbs in the headlights and there is a small improve,ent...cost £15 so cheap enough to try.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
clip
and the Borghi bar from Italy is the other option. This is not a badge bar (which would vibrate) but is fixed to each overrider for added stability. Of course this means drilling a hole in each overrider.
The photos of mine are at http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/99681/Since these photos were taken I have fitted some badges.
Posts: 6,958 Likes: 117
Posts: 6,958 Likes: 117 |
As has been said, a very nice neat job.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I rarely drive my Morgan at night.... but I did in France last summer. It was huge fun with the top down at night. I felt like a kid all over again.
+8 4.8
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Can I refer you to an earlier Post on this very subject... Spotlights Brackets for cars with Over riders
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
As has been said, a very nice neat job. Looks excellent
Posts: 347 |
Thanks for the suggestions. I rather like the brackets behind the overiders. I was very interested to note that no-one mentioned the risk of cracking of the wings. I think I will go with bolting the lamps directly on to the wings using the rear facing bracket. That option seems to be the neatest since although the MMC brackets are certainly substantial it results in several bolts being visible. Mounting directly on the wings also gives an option of using a bracing bar behind the wing if necessary.
2014 +4, Le Mans Blue / Magnolia "Meg" the Mog
Posts: 2,433 Likes: 66
Posts: 2,433 Likes: 66 |
The Librands brackets are superb well made all stainless i fitted them on my plus four they come with a thick rubber gasket and no vibration, much better than the Morgan ones they have a hole integral on the bracket with a rubber gromet to feed the wire through. They also look very good you wont be dissapointed.
Em
Em I think they might have been better at one time but the ones currently available through MMC are pretty nice and they do have a hole for the wire
Go compare thats the answer.
Em
