2 members (Alan Patterson, Zach), 181 guests, and 71 robots.
Topics49,848
Posts837,395
DazMog, The Impaler, tlchzj79
#266959 13/04/15 11:00 AM
solomog Offline OP
On Friday afternoon, driving down to the West Country the rear brakes seized on my Plus 4. The initial warning / symptom prior to the brakes seizing on was a soft brake pedal at the first push then on the second push the brakes felt solid and the car stopped fine. The (what turned out to be) very good news was I was only 2 miles from Berrybrook Morgan and their top mechanic Bradley. I nursed the car into Berrybrook followed by a nasty burning smell, not just from very hot brake shoes, it was a bit scary. The bad news for Bradley was I arrived just as he was clearing up to go home. Bradley instantly knew what the problem was and replaced both rear brake slave cylinders together with the shoes. The cylinders had seized solid. Bradley completed the task in about 2 hours, all in his own time, going way beyond the call of duty, and we were on the road again at about 7.00pm. There are two lessons to learn from this story 1. If you are going to breakdown then make sure you are close to Berrybrook Morgan, they could have easily said “leave the car here and we will make a start on Monday” but they were as keen to see me back on the road as I was to get going, absolutely amazing service, and 2. when Dave tells us to replace the brake fluid every two years, make sure you do it or, like me, you end up with corroded brake cylinders and the potential of a much sadder tale than this one.
Jeff
2009 Black & Tan +4
solomog #266965 13/04/15 11:10 AM
That's excellent service - virtual beer to Bradley! smile
+8 4.8
solomog #266969 13/04/15 11:31 AM
Yes the brake fluid change is certainly something that has to be added to maintenance schedules every 2 years.
Also it is not a bad idea to remove the rear drums every 6 months or so and look for any signs of leaks or corrosion around the cylinders, agreed this is internal cylinder corrosion we are talking about but there are generally some tell signs that all is not well when this is happening, and a visual gives you advance warning.
Andy G
1999 +8 , Indigo Blue.
solomog #267030 13/04/15 02:58 PM
Sad start-happy ending! Well done Bradley for getting you mobile again so promptly. As for fluid changeing, have you got an Eezi-Bleed or something similar? Makes the job dead simple and can be done by just yourself. Gerry.
http://www.cjautos.eu/EEZIBLEED_KIT_p/g4062.htm
solomog #267037 13/04/15 03:27 PM
SBM Offline
Wow, that's excellent service from Berrybrook!
Proof positive, as if any were needed, that Morgan folk are a genuinely nice bunch.
Another virtual beer from me. Cheers Berrybrook.
cheers
solomog #267056 13/04/15 04:23 PM
Berrybrook is my local agent - I have nothing but praise for their service.
solomog #267061 13/04/15 04:48 PM
Like John, I use Berrybrook and Bradley looks after my 4/4. Top bloke and superb mechanic.
cheers
Bud
4/4 "Stanley"
solomog #267078 13/04/15 05:42 PM
Berrybrook are amazing , my Mog came from there originally , very good service indeed !
