4 members (gmcn, Pigiron, Craig Jezz, sbarracl), 222 guests, and 46 robots.
+8Rich 91
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,336
Christoph
#267326 14/04/15 07:04 PM
E
EJS Offline OP
E
Does a 1990 Plus 8 come standard with an electrical outlet in the dash for plugging in GPS? (In states we call it a cigarette lighter). If not can one be easily adapted?
thanks John
EJS #267397 14/04/15 11:16 PM
I don't know if they did as standard but can be very easily fitted.
EJS #267400 14/04/15 11:28 PM
might not be in the dash. try in back underneath.
1997 +8
EJS #267417 15/04/15 06:18 AM
Drive on the Wild Side
My 96 plus 8 had it under the dash left Side of the steering column, be worth looking there. I did not notice till I upgraded the dash cheers
Adrian
EJS #267431 15/04/15 07:15 AM
Very simple to install, pop a line fuse in the feed wire for safety especially if you are making the feed permanently live as they are on most cars. You can also use the socket for a battery conditioner then.
BR Colin
EJS #267457 15/04/15 10:40 AM
As Colin says they are very simple to install.
I put a waterproof socket in the vertical shelf behind the seats, with leads going back to the battery terminals. On Colin's recommendation I did fuse it as it is permanently live. The only watch point is to ensure that you wire the earth side up correctly, the external case of the socket is the earth side of the circuit.
Andy G
1999 +8 , Indigo Blue.
EJS #267458 15/04/15 10:44 AM
I've got 2 - a switched supply to a triple output screwed to the outside of the glovebox with the sockets pointing downwards. This is fused at 10A and is used for dash cam and satnav.
The other is mounted on top of the transmission tunnel at the rear, up against the rear bulkhead. It is directly connected to the battery so it is always live, and is fused at 15A. I have used it for powering the laptop when data logging from the OBD port.
EJS #267515 15/04/15 02:53 PM
I fitted one on my previous 1993. 4/4.
Made a bracket for it and screwed it to the frame up under the passenger side dash.
Found a spare wire in the loom for connection and included an in-line fuse. It was ignition controlled so not permanently live. Cost less than £10 for all parts.
EJS #267540 15/04/15 04:27 PM
EJS, there are numerous ones that can be bought from any auto parts store. Most will require some wiring connections. There is another that comes with two alligator clips to connect directly to the battery and about three feet of wire. I use this kind in my Series 1 where I don't want to violate the originality.
PS Where in the US are you?? I'm in Florida.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
EJS #267643 15/04/15 10:51 PM
E
EJS Offline OP
E
Thanks to all for the input. Have ordered one online. Mark, I am in Deland Florida. Picking up my "new" Morgan Plus 8 in UK in about two weeks and headed for France. When do you leave for Wales? Cheers.
