10 members (Simon, GrumpyPa, TalkMorgan, Gordon D, Craig Jezz, TBM, scortroadster, chanteclair, SteveT, DPEvans), 402 guests, and 132 robots.
Sagging Hood
Topics49,859
Posts837,479
Page 2 of 4 1 2 3 4
Matty #270724 27/04/15 07:16 PM
In Vermont it is almost laughable:
VIN # check
Wheels attached check
lights work check
signal, brake light and hazard light function check
Attach sticker pay $30 motorcycle fee and leave
Matty #270725 27/04/15 07:17 PM
Matty Offline OP
Hi thanks for all,the advice.
Nearside unit bowl rusted thru at the base,which is presumably why there is no real adj.
drivers side not rusty but unless I am being really thick I cannot see an adjusting mechanism of any real utility. I have slackened and pushed the bowl upwards very slightly and I reckon it will do. Horrible engineering and the quality of the unit is terrible. Will be replacing asap.
Matty #270740 27/04/15 08:11 PM
Yes, the base of mine cracked, admittedly on a nasty pot hole.
the base cup is very thin but has an oval shaped apeture for vertical beam adjustment.
its a difficult art not tightening it too hard and keeping the support wahser properly round the appeture.
Matty #270743 27/04/15 08:12 PM
I tried looking but there arent many on the market. Caterham ones are too small.
Matty #270751 27/04/15 08:30 PM
JMD Offline
Our early one now has a nice shiny MOT ticket alongside a service...no material issues with either...now for return of some warmth for a summer of fun!
Matty Offline OP
The standard unit looks a bit like ones from Holden
JMD #270757 27/04/15 08:46 PM
Matty Offline OP
Good for you
But wait till you have 15000 miles on the clock!!!!
Matty #270759 27/04/15 08:54 PM
I don't think tricycles are subject to (our equivalent to) MOT. Yet.
I know the legislation on motorbikes is ready and about to be published, and will check if it rules on three wheeled vehicles. I suspect YES, mostly because there are nowadays hundreds of three wheeled piaggios circulating in urban areas, it has become a very fashionable kind of scooter.
Anyway, so far if it has less than 4 wheels no "mandatory periodic inspection" (that's what they're called here) is needed.
And for regular cars (not the case with trucks and lorries) the first inspection is only when they reach 4 years after build. Then 6, then 8, then every year.
Owning a 2014 three wheeler, and if the same logic applies, I suppose it'll be subject to inspection in 2018, if indeed the relevant legislation is published.
2010 Morgan +4
2014 M3W Brooklands
To be raced
Matty #270801 28/04/15 06:41 AM
Matty there maybe a grub screw on the tube the lamp bolt passes through, 7/64 inch on mine.
Tim
Matty #270970 28/04/15 06:07 PM
Matty Offline OP
There is but that's for direction.
There is an elongated hole in the bowl that is meant to aid adj. however when you tighten it tends to point down. I think I have got it just good enough.
Re- test on Friday.
Page 2 of 4 1 2 3 4
