8 members (IcePack, Alan Patterson, Vansrv6, aerotaff, Ritchie B, Image, Ncik P, BLUE+4),
371
84
Topics49,851
Posts837,443
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
In Vermont it is almost laughable:
VIN # check Wheels attached check lights work check signal, brake light and hazard light function check
Attach sticker pay $30 motorcycle fee and leave
Posts: 797 |
Hi thanks for all,the advice. Nearside unit bowl rusted thru at the base,which is presumably why there is no real adj. drivers side not rusty but unless I am being really thick I cannot see an adjusting mechanism of any real utility. I have slackened and pushed the bowl upwards very slightly and I reckon it will do. Horrible engineering and the quality of the unit is terrible. Will be replacing asap.
Posts: 522 Likes: 1
Posts: 522 Likes: 1 |
Yes, the base of mine cracked, admittedly on a nasty pot hole. the base cup is very thin but has an oval shaped apeture for vertical beam adjustment. its a difficult art not tightening it too hard and keeping the support wahser properly round the appeture.
Posts: 522 Likes: 1
. Will be replacing asap. I tried looking but there arent many on the market. Caterham ones are too small.
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
Our early one now has a nice shiny MOT ticket alongside a service...no material issues with either...now for return of some warmth for a summer of fun!
Posts: 797 |
The standard unit looks a bit like ones from Holden
Posts: 797 |
Good for you But wait till you have 15000 miles on the clock!!!!
Posts: 1,642 |
I don't think tricycles are subject to (our equivalent to) MOT. Yet.
I know the legislation on motorbikes is ready and about to be published, and will check if it rules on three wheeled vehicles. I suspect YES, mostly because there are nowadays hundreds of three wheeled piaggios circulating in urban areas, it has become a very fashionable kind of scooter.
Anyway, so far if it has less than 4 wheels no "mandatory periodic inspection" (that's what they're called here) is needed.
And for regular cars (not the case with trucks and lorries) the first inspection is only when they reach 4 years after build. Then 6, then 8, then every year.
Owning a 2014 three wheeler, and if the same logic applies, I suppose it'll be subject to inspection in 2018, if indeed the relevant legislation is published.
Posts: 1,947 |
Matty there maybe a grub screw on the tube the lamp bolt passes through, 7/64 inch on mine.
Tim
Posts: 797 |
There is but that's for direction. There is an elongated hole in the bowl that is meant to aid adj. however when you tighten it tends to point down. I think I have got it just good enough. Re- test on Friday.
