8 members (JMD, Morganmike, Ubiquitous, Jens, High Hamster, Moggo, RibbleAdventures, John V6), 273 guests, and 30 robots.
+8Rich 64
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,360
Members9,215
Rbt Aero8, Salmon, stevends
LarryS Offline OP
Here's another in the never ending M3W battle against rattles; I have a rather annoying rattle which sounds more like chirping coming from behind the steering wheel or, behind the dash. It is more audible at lower RPMs, but maybe I just can't hear it at higher revs, not sure. Can't find anything loose underneath. Could the steering wheel be rattling on the splines? Doesn't feel loose, though. Any ideas?
I had a chirping rattle noise coming from the same area as you describe and I fixed it by wedging a piece of felt between the steel tubular frame and the metal at the bottom of the dash area. When you hear the noise, grab the dash aluminum near where the unused 12v plug hole is and pull it toward you slightly and see if it quits chirping; if so that is where the sound is coming from and felt is the answer.
Charlie, Former Editor
LarryS Offline OP
Thanks, I'll try your fix and let you know if it worked. Thanks, LarryS
At various times I have felt that this car is nothing BUT a collection of annoying rattles and chirping sounds.
When something goes quiet it has usually meant that it finally fell off or just broke...
i had a chirping noise coming from friction between wood frame and chassis. Just retighten the bolts on passenger and driver side.
After removing the all the baffles (total of six) I can no longer hear any squeaks or rattles. Guess that's a plus. Also on the plus side the right pipe has a lovely "twitter" on overrun, just like my DBD Goldstar, neat.
LarryS Offline OP
Thanks, tried that, no luck there. Next step; mechanic's stethoscope or similar.LarryS
Not what I am sure you want to hear, but it may be the compensator.
The squeak in mine has now become so annoying that I am going forward on the Centa upgrade.
A stethoscope will help locate where it is coming from.
Good Luck.
Past The City Limits
Met a guy who said he had a zerk installed in the compensator, but to do so a hole had to be cut in the bell housing to install the zerk. Anybody had this done? Do you know where the hole in the bell housing has to be drilled? The measurements? He said that anytime the compensator started to rattle he just gives it a shot of grease. Is this guy "pulling my leg"?
Mine has been equiped
A shot of grease Time to Time And after 13000 miles my compensator is always running
