8 members (Rog G, Rex_tulips, Gordon D, linklaw, Dek, brownbaker, Mark Simmons, Mike D),
314
42
New
Topics48,365
Posts813,379
Members9,215
Posts: 164 |
I noticed in the technical specs for the 2012-2013 M3W that the rear tire size is listed as 175/55R16, however the rear tire on my 2014 model is 175/65R15.
Was the earlier tire size a misprint or did Morgan change the size of the rear wheel in the 2014 model year?
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
The tyre size on my mid year 2013 M3W is listed as 175/65/15.
Posts: 11,868 Likes: 138
Posts: 11,868 Likes: 138 |
Or maybe it was misprinted once and lazy journalists have just been copying from each other without bothering to check the actual cars?
A bit like the canard that the 4/4 was referred to before the war as a 4-4. A mistake printed in loads of books and articles with no evidence for it, and if you look at the actual cars and the factory build records they have 4/4 on them.
Posts: 1,213 |
My Sept 12 one has a 15 inch wheel , I suspect it's a missprint .
Hugh
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
Possibly changed from 16" to 15" early in the development stage. Some very early cars had a disc brake on the rear hub and a narrower drive belt, if I remember right. These were soon changed to drum brake hubs and a wider belt.
Posts: 133 |
Mine is a 2012 model with 15 inches wheel. I have the same suspect of HJP
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
Posts: 2,356 Likes: 2
Posts: 2,356 Likes: 2 |
Posts: 1,015 Likes: 1
Posts: 1,015 Likes: 1 |
I'd be amazed if they're not all 15" rear wheels.
