Morgan Aero 8
3 members (Montegue, ChrisConvertible, JMcL), 320 guests, and 73 robots.
+8Rich 70
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,714
#275267 18/05/15 09:29 AM
Bren Offline OP
My manual Plus 8 is now 18 months old with 3000 miles on the clock. 450 of those were done over the weekend on a trip to Somerset which was hugely enjoyable. On the return journey, however, when backing off the throttle on to the brake or vice versa at low speed in either first, second or third gear there is an audible clunk. I will certainly get the car looked at whilst still under warranty but wondered whether any of you have experienced this and if there is an easy fix ? Any help will be much appreciated.
Bren
Plus 8
Rhodium Silver with black leather
Caterham 620s
Bren #275270 18/05/15 10:26 AM
I get a slight driveline effect at very low revs if I'm lazy but this sounds worse and seems as though it wasn't there before.
I wouldn't say what I get is a clunk - but it is driveline shunt, and not really all that bad at all. Sounds like something might need tightening or adjusting...
Bren #275274 18/05/15 10:41 AM
Limited slip dif ??
Bren #275279 18/05/15 10:57 AM
Sounds very alarming on the Mk1 the first time you hear it and is noticeable all the time till you get used to it.On your plus 8 its more or less all gone, i suppose you might get it in high gear at very low speed (wrong gear)pulling away.If its noticeably clunky better get it checked out. Slight creaking noises whilst parking or in tight areas are all the rose joints having a bit of a strech.
Em
Bren #275379 18/05/15 07:02 PM
Just spoke to a mate of mine who knows the plus 8 very well,in its BMW application its fitted with a harmonic damper apparantly there is no room on the new plus eight to fit one.So you will get a little bit of a shunt at slow speeds but nothing like the MK1 Aero,hope this puts your mind at rest.
Great car Em
Bren #276570 24/05/15 04:04 AM
From the experience I have had just recently get the prop shaft bolts checked...
Morgan Plus 8 Speedster
2015 Defender 90 - Twisted/Bowler Mix
Bren #279423 05/06/15 02:54 PM
quick update, replaced all propshaft bolts and nuts, no clunk etc whats so ever a low speeds its perfect smile
Formerly known as Aldermog
As it should have been when delivered!
Glad it is now finished and ready for enjoyment.
Bren #279777 08/06/15 08:57 AM
Good to know. Have fun in the current excellent Morgan'ing weather!
Bren #279783 08/06/15 10:16 AM
Bren Offline OP
Many thanks for your comments. The car is booked in to Stratstone tomorrow.
Bren
Plus 8
Caterham 620s
