10 members (britmog, Dada, RJW, Rex_tulips, John Winn, Alan Patterson, david nathan, Graham, G4FUJ, BobtheTrain, Gordon D), 294 guests, and 37 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,393
Members9,215
Rbt Aero8, Salmon, stevends
trevmar Offline OP
Does anyone know of a maker or supplier of longitudinally divided hinged insulating connector covers (as described in a patent numbered US 3147338 A) ?
I ask as having relocated the battery to the rear of my plus 8 I now have the main battery cable running along the floor inside, and since there is a join in it anyway right by the gear lever it makes sense (to me) to have this as the "jump-starting point" rather than groveling around on the starter solenoid terminals which are perilously close to bare metal.........
Ray Offline
Warning. their is a lot of chassis near there.PS What I have done is found the main cable to the starter as it exits the bulkhead, then stripped approx. 1 inch of cable. Easy to reach. when not in use cover with a piece of split hose to insulate.
I have just got one of these for that very purpose:-
http://www.ebay.co.uk/itm/270717638154
2015 Plus 4 (GDI) Sport Green
trevmar Offline OP
athelstan- many thanks.
Only logistical hurdle now is although I was born where you live, I now live in the Left Colonies 9California) so sadly will cost more to ship than the cost of the item........I don't suppose there are any clues on yours as to the maker?
This arrangement may not suit your location, but on the MBGV8, there was a split connector on the main battery feed on the inside of the chassis leg. It was a simple threaded stud through a flat steel bracket, but insulated with a top hat (at each end) profile nylon bush. The flat steel bracket was then secured to the chassis with two captive studs and nuts, but also insulated with nylon bushes. The battery feed connectors were then covered with standard caps - as fitted to an old fashioned solenoid.
You can see the arrangement here:
Sorry Trevmar, anonymous I'm afraid. Any good ships chandler should have these in stock, or how about:-
http://www.texasindustrialelectric.com/_junction_blocks.asp
or
http://www.waytekwire.com/products/1439/Junction-Blocks/
