0 members (), 203 guests, and 89 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#294165 05/08/15 11:14 AM
griffo Offline OP
What's the best way to get to the front propshaft UJ grease nipple on a Plus 4 (2014). From underneath it's hidden away above a crossmember and my grease gun won't get on it. Remove trans tunnel trim from inside the car and cut an inspection hatch???
griffo #294172 05/08/15 11:38 AM
Possibly cut an inspection hatch...you cannot rotate the rear wheels to give better access?
griffo #294190 05/08/15 12:40 PM
E
eds Offline
E
Same with 4/4 sport. I couldn't work out how to do it so I asked the mechanic at the local Morgan dealer. Get a flexible hose on the grease gun, rotate the propshaft until the nipple is vertical i.e. sticking up straight up, then with a bit of fiddling you can attach the hose to the nipple. That's why you need a flexible hose. I have used this procedure for the last 3 years.
Best of luck
Eddie
2009 4/4 sport
griffo #294201 05/08/15 01:22 PM
griffo Offline OP
"you cannot rotate the rear wheels to give better access?"
The problem is Richard it's not possible to get the connector end of the grease gun into the u/j. I've even tried grinding the connector (which is on a flexible pipe) but it still won't get in there. In desperation I've ordered one of these:
http://www.ebay.co.uk/itm/281470781572?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
off Ebay. It looks a bit slimmer so I'll report back when I get it if it works.
griffo #294206 05/08/15 01:52 PM
You could ring Perranwell and ask how they do it, they are always willing to impart tricks of the trade
griffo #294232 05/08/15 03:42 PM
Ray Offline
Try jacking the rear axle up or down it will change the angle of the UJ and propshaft.
griffo #294294 05/08/15 08:11 PM
Take the nipple off and put a right angle nipple on or one that you can reach with a grease gun ?
griffo #294295 05/08/15 08:18 PM
Griffo, it's very tricky, I kind of managed it with one of my old grease guns that seems to have a slightly slimmer end than normal..even then I found it had to be just in the right spot to get any into the UJ and it was very messy. Persevere it can be done but I'd be interested if anyone has a better way.
griffo #294307 05/08/15 09:08 PM
On my Roadster I can get at it from underneath through the tunnel. On Mr Bumble I opened up a small hole between the floor boards, and with a torch can access it from directly underneath. Limit the number of strokes into the UJ's. A couple will be enough.
griffo #294358 06/08/15 06:13 AM
Hi Griffo
I use one of these type adaptors for my grease gun.
http://www.ebay.co.uk/itm/Sealey-170mm-N...=item4ce42c601c
As DaveW said small hole of about 20mm under the Mog and slightly off to one side of the UJ's.
Cain
Cain
Wolf Cafe Racer
4/4 Sport
