4 members (Bob_Price, Lordofthewings, itsfrank666, vbalddave), 278 guests, and 67 robots.
John V6 68
+8Rich 66
DaveW 64
9,208 Registered Users
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,346
Posts813,059
Captain Morgan, IRWIN
Obviously I have all the relays/fuses, test circuits, torch, Hi-Vis etc. Don't forget a piece of wood to stand the jack on if the ground is soft (and if you have a spare wheel).
mapman Offline OP
The way this post is going I may need a trailer!
M3W 'The Mapmog' Built June 2015
For long trips in my M3W I take in no particular order:
Metric ring spanner set plus 24mm and 36mm spanners, 3/8 socket set metric and A/F, large adjustable spanner, mole grips, Allen keys metric and imperial, couple of screwdrivers, tyre levers, spare inner tube, tyre inflator, scissor jack, large plastic cable ties, large metal cable ties, gaffer tape, spare cam belt and dowels, spare throttle cable, spare rubber bobbins, used to have spare rectifier until I used it, mobile phone and insurance.
All of that fits under the bonnet.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
WD40, Gaffer Tape, Hammer.
If it should move & doesn`t-- WD40
If it shouldn`t move & does --- Gaffer Tape
If you can`t fix it with a hammer it`s an electrical problem.
+1 roflroflrofl
Red Leader drive
AA card & mobile phone. Never let me down yet! (The car that is - not the AA card...)
Andy
1 Air compressor
2. Spare tube
3. 8,10,13,17,19mm spanners
4. Phillips, pozy and flat screw drivers
5. 1/4 drive socket set
Cable ties, insulating tape and AA gold card.
Damm, now I've got tool case envy!
Do you also have the wheel nut wrench or have you got eared spinners?
Andy
While it's a oft quoted mantra, WD40 is largely useless. It displaces moisture by attracting it and allowing the moisture to fall away with excess WD40. It's a rubbish lubricant, just about any proper oil is better.
Glad to see so many votes for cable/zip ties. I've even fixed the rear spring shackle on a luton bodied transit with one!
Spinners
