Morgan Aero 8
10 members (BLUE+4, Craig Jezz, CooperMan, TeddyAds, GrumpyPa, Horror, +8Rich, Joske Vermeule, Dek, Gordon D), 213 guests, and 61 robots.
+8Rich 76
Topics49,860
Posts837,526
Jonny72
Page 3 of 3 1 2 3
Shooter #307812 27/09/15 11:40 AM
Formerly known as Aldermog
Originally Posted By Shooter
On the Aero the tyre would rub and the only option would be to cut away part of the front splitter. I'm guessing the Plus 8 would be the same
The +8 has no splitter, there is masses of space in front to the wheel...
As the profile is in both cases 35% the difference in sidewall heightbetween 225 and 235 is 3.5cm, ie. the 235 wheel is is 7cm taller than the 225, based on using this calculator:
Calculator
But that is almost 3", there is little clearance between the wheel and wing edge so it might catch the wheel arch on lock....
Neilda #308018 28/09/15 09:16 AM
Someone removed the 'who did it' from my post I think... If it works this time it was Brands Hatch Morgans who sent the wheel away but I don't know who they sent it to. Great job - my wheel was MUCH MUCH worse than yours and now looks perfect.
Neilda #308213 29/09/15 12:24 AM
As far as I am aware plus 8 and Aero wheels are made by RAYS of Japan and imported by Co-ordsport in Tipton, West Midlands.
Several dealers nationwide including Demon Tweeks.
All the above have websites, hope this helps!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Peter J #308234 29/09/15 06:37 AM
Mr Fezza
Mr Fezza
Calculator
It can't be 3 inches difference between a 225 wide and a 235 wide tyre!
235 x .35 is 82mm
235 x .35 is 79mm
So that's a 3mm difference. Not 3cm
To get a 3cm difference you'd need to go from 225to a 335 tyre width!
Maxxed out!
Taffmog #308247 29/09/15 07:10 AM
Neilda Offline OP
Very helpful - thank you very much...
They look like Volk Racing wheels off page 28 of their huge catalogue (caution, large file):
http://www.rayswheels.co.jp/DB/catalog/2015/pdf/2015SUMMER_all.pdf
+8 4.8
Neilda #308765 30/09/15 08:59 PM
I've spoken to John Burbidge and the wheels are supplied by Speedline and are Corsa.
Neilda #308771 30/09/15 09:08 PM
Neilda Offline OP
Hi Mike - yes Steve Morris replied and was very helpful.... although I still didn't discover who made them. smile But he offered to help - speedy response and can't be faulted.
Jay, you're a star - thanks so much for taking the time out. I will research away now I know! Virtual pint to you.
+8 4.8
Neilda #308806 30/09/15 10:42 PM
Yes confirm MMC use both RAYS and Speedline !
The Speedlines are 'Corsa' but not shown on their website. I don't know how to upload a pic (!) but the details are:-
MR01 FMR01--1S
8.5J x 18H2. ET26.5
5 x 114 00001658
Silver. Steel lip. 270/12
(1CPG MORGAN01 D031)
As far as I can see 18'' wheels are Speedlines, 19'' are RAYS
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Taffmog #308861 01/10/15 06:59 AM
I confirm the 19" "Aeromax" wheels are Rays, made in Japan and forged, not cast. So probably horribly expensive.
Neilda #309136 01/10/15 10:20 PM
I have RAYS on my Donkervoort GTO, 18 in the front and 19 in the rear
A set of four wheels costs 12.000 Euro.....
RAYS doesn t supply those to the public, just to the factory as dimensions are specific
I bet the agreeement with MMC is similar somehow
Page 3 of 3 1 2 3
