4 members (jbk, Calypso Red, TBM, Montegue), 276 guests, and 91 robots.
Topics49,847
Posts837,389
Page 3 of 3 1 2 3
I did hear that the bolt is a quite different design but haven't seen it.
Should be a recall without any doubt given the number of failures and the 'fix'.
Originally Posted By PhilipNZ
Originally Posted By MorganMatt
How is this problem solved on 2014 and newer models? Does Morgan just install washers/bolts at factory, or is there a redesign of the cover?
I had a close look at mine. I think there are still washers in there but there are 2 horizontal 1mm slots on the front where the casing ridges are. I'm not game to take it off to see what they have done with the pulleys.
Apologies I havnt done some photos yet , life is hectic at the moment. Will do over the weekend.
Found a way to get at these pictures while at work !
This is my car with the kit fitted. If you zoom in on the drive pulley bolt , you can see its not a torx , its a fancy hex head not sure what the proper name is.
This is the new timing belt cover with the slots. Looks pretty cool I think
Good pictures! I notice that all the bolts have witness marks which is a really nice touch. I think I'll pull the cover, check the pulley bolt and put a paint blob on it. It hasn't moved as far as I can tell in 13,000 miles but this would be a way to be sure nothing destructive is going on down there.
Do you think a car being made this week will have the new cover and pulley bolt if not should I ask why not
If Morgan have a batch of pre modified engines they will use them up & it seems unlikely they will change them.
ZK-Mog
ZK-Mog
My car made in June has the new cover so I'd be fairly sure you're right on both counts
Page 3 of 3 1 2 3
