2 members (Bunny, Bitsobrits),
324
50
Topics49,843
Posts837,341
Posts: 782 |
I did hear that the bolt is a quite different design but haven't seen it.
Should be a recall without any doubt given the number of failures and the 'fix'.
Posts: 1,562 |
How is this problem solved on 2014 and newer models? Does Morgan just install washers/bolts at factory, or is there a redesign of the cover? I had a close look at mine. I think there are still washers in there but there are 2 horizontal 1mm slots on the front where the casing ridges are. I'm not game to take it off to see what they have done with the pulleys. Apologies I havnt done some photos yet , life is hectic at the moment. Will do over the weekend.
Posts: 1,562 |
Found a way to get at these pictures while at work ! This is my car with the kit fitted. If you zoom in on the drive pulley bolt , you can see its not a torx , its a fancy hex head not sure what the proper name is. This is the new timing belt cover with the slots. Looks pretty cool I think
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
Good pictures! I notice that all the bolts have witness marks which is a really nice touch. I think I'll pull the cover, check the pulley bolt and put a paint blob on it. It hasn't moved as far as I can tell in 13,000 miles but this would be a way to be sure nothing destructive is going on down there.
Posts: 303 |
Do you think a car being made this week will have the new cover and pulley bolt if not should I ask why not
Posts: 1,947 |
Do you think a car being made this week will have the new cover and pulley bolt if not should I ask why not If Morgan have a batch of pre modified engines they will use them up & it seems unlikely they will change them.
ZK-Mog Talk Morgan Regular
Posts: 584 |
My car made in June has the new cover so I'd be fairly sure you're right on both counts
