10 members (DJC, nick w, Tweed19er, DaveK, Pyewacket, david nathan, Graham, G4FUJ, James B W, BobtheTrain, Tresco), 431 guests, and 41 robots.
John V6 68
DaveW 64
+8Rich 62
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,071
Captain Morgan, IRWIN
titus Offline OP
Has anyone bought the Bilstein rear shocks advertised to match the Suplex front?
How have you found them ?
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
Yes , I use the the Bilstein rears on my +8. IIRC they are the units which were specified for the Series 1 Roadster, which was set up as "soft" as MMC dared to use at that time.
It does make the rear end slightly more compliant over the gentler bumps, and due to the the fitment of bump stops inside the units , it does seem to cope with the larger hits as well.
Andy G
1999 +8 , Indigo Blue.
PJB Offline
Andy G is indeed correct with respect to the model they were originally specified for. Regards PJB.
I had them as standard on the back of my 08 4 seater, hard to tell how good they were as the rear springs collapsed twice they were so soft until the factory revised them and cured the problem, shortly after that I sold the car.
BR Colin
titus Offline OP
Thanks everyone.
I spoke to Rob Wells this morning at Librands and he will check with Suplex and Bilstein to see how they are set up and if they are suitable for the four seater.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
PJB Offline
The Bilsteins as std on the rear of the 4 seater as photo attached with the long white 'spring assist' are NOT the same as those on the rear of the 3.0 V6 Roadster. Different valving, bump stop etc. Regards PJB.
titus Offline OP
Thanks for the photo Peter.
I can now see what it should be like.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
