Topics49,848
Posts837,406
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 37,408 Likes: 977
Posts: 37,408 Likes: 977 |
I'll take the Vulcan and check the system out for us all About 2100 I exaggerated 2200  .
Posts: 4,896 |
Based on the system does this mean the oil cartridge will cost more than the car and the car will become a cheap throw away?
Adrian
Posts: 5,210 |
Interesting idea. If MMC adopt it there will be some owners complaining it's not like the old way of changing oil.
The easiest part of the oil change is refilling - now if they had an autodrain function and autofilter change I would be interested.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
But draining is easy - you just put the lance from the Pela or similar into the dipstick hole and leave it to suck the oil out.
I think the oil ends up back int eh cartridge somehow - pure plug and play...now if you could do that with coolant and brake fluid (no bleeding) then I'm interested
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Sounds like dry sump with a replaceable tank to me.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Are they in danger of solving a problem that doesn't exist?
My Beemer only needed it's 1st oil change at 18,000 miles and at 31k is still nowhere near the 2nd.
Car manufactures and oil companies are working towards ever longer service life and eventually we'll see the sealed for life engine.
Red Leader
But draining is easy - you just put the lance from the Pela or similar into the dipstick hole and leave it to suck the oil out. I'm not keen on the magnetic plug getting saturated with metal bits and besides a good flushing agent is a good idea.
