10 members (Robbie, JMcL, B3MOG, gazum, +8Rich, High Hamster, Paulxj, MJF, DCH, Strathaven),
253
54
Topics49,863
Posts837,554
Posts: 12,258 Likes: 317
Posts: 12,258 Likes: 317 |
If the springs are different lengths, you have not been sent a pair. The springs themselves are not symmetrical, in that the mounting point for the axle is not the same distance from each end of the spring, but the springs themselves should be the same as each other.
Are you sure you are measuring each spring from the same end? One way round the mountings will line up, the other way round they will appear differently spaced.
Posts: 22,362 Likes: 353
Posts: 22,362 Likes: 353 |
I think I understand the question now. The axle locating bolt/dowel is not the same distance from each end of the spring. This is normal. The thickest part of the spring is in front of the axle. There is always a slight variation in unloaded camber so as you say - fit the one with greater curve on the drivers side.
Posts: 82 |
Tkx dave that what i ment Sorry if my explication was a bit difficult But english is not my strongest point I will let you know this weekend if al,goes well Gr tom
Posts: 82 |
Job done car sits right hight both sides equal Started 7.30 pm done both sides 3 pm wth 2 persons Indeed fidly job with washers on boldts in the back sude Tkx guys Gr tom
That is a good effort Tom and completed in dealer time. Well done.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
