9 members (+8Rich, DaveW, CRL, hillclimber, moggin, TeddyAds, sewin, Ncik P, verysideways), 210 guests, and 69 robots.
+8Rich 78
DaveW 50
Topics49,864
Posts837,570
Page 3 of 3 1 2 3
If the springs are different lengths, you have not been sent a pair. The springs themselves are not symmetrical, in that the mounting point for the axle is not the same distance from each end of the spring, but the springs themselves should be the same as each other.
Are you sure you are measuring each spring from the same end? One way round the mountings will line up, the other way round they will appear differently spaced.
I think I understand the question now. The axle locating bolt/dowel is not the same distance from each end of the spring. This is normal. The thickest part of the spring is in front of the axle.
There is always a slight variation in unloaded camber so as you say - fit the one with greater curve on the drivers side.
tom+4 Offline OP
Tkx dave that what i ment
Sorry if my explication was a bit difficult
But english is not my strongest point
I will let you know this weekend if al,goes well
Gr tom
tom+4 Offline OP
Job done car sits right hight both sides equal
Started 7.30 pm done both sides 3 pm wth 2 persons
Indeed fidly job with washers on boldts in the back sude
Tkx guys
Gr tom
That is a good effort Tom and completed in dealer time. Well done.
Great to hear.
Page 3 of 3 1 2 3
