6 members (John Winn, DPEvans, Davetherave, TBM, BobtheTrain, Craig Jezz), 315 guests, and 84 robots.
Sagging Hood
Topics49,859
Posts837,478
#317632 07/11/15 08:20 PM
Pud Offline OP
Good evening, would anyone know what the yellow padlock warning light means on my 2014 +4 Dashboard. Surprisingly it is the one light not described in the handbook! Genius read
Thank you
if it was put together by hand I can repair it.
+4 x 2
Pud #317633 07/11/15 08:28 PM
Immobiliser warning?
Pud #317643 07/11/15 08:59 PM
Black Rat
Black Rat
That's a new one on me sherlock
A Google search suggests it's an electronic steering wheel lock warning and the steering wheel needs to be moved slightly to release. Best I can do idea
Keith
2013 narrow bodied + 4 Ruby.
Pud #317647 07/11/15 09:08 PM
Just a guess, immobiliser problem.
Try a different key to see if the light goes out.
......Beaten to it
Ian
Pud #317648 07/11/15 09:13 PM
Unlock the garage door before you drive out? laugh2
I would think immobiliser circuit too..
Pud #317689 08/11/15 07:54 AM
All (" modern" cars from the last 15 years) have an transponder in the key, it makes elektronik contact with the system so the key is not only an mechanical unit but also elektronik .... and if it fails .... you get somtimes an yellow padlock on the dach ..... but i dont now if it is also in an Morgan key ........ but ... Morgan +4 keys are from Ford ? and Ford had it for at least 15 years
Stefan
2001 4/4
AR 4 soon
Pud #410394 25/11/16 05:33 PM
I have the same issue - flashing yellow padlock on my 2014 Plus 4. Everything works but this light now comes on when the key is out instead of the normal flashing immobiliser light - any ideas appreciated
Pud #410432 25/11/16 08:13 PM
Ditto. Don't worry about it.
Pud #410443 25/11/16 08:40 PM
It means that you are exceeding the terms of your ASBO.
Pud #410454 25/11/16 09:41 PM
If it is a padlock on its own then it is normally to do with door locks - if it's a padlock on top of a car symbol then it's a passive anti theft system
Mark - No Longer driving
