Topics48,364
Posts813,344
Members9,215
Posts: 11,610 Likes: 43
Posts: 11,610 Likes: 43 |
It's a funny thing this aversion to drilling holes in the car - we presumably don't balk at the walls or floors of our homes? I've never been pestered to put shelves up in the Morgan
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
Morgan drill quite a few holes in the chassis, don't they? I don't suppose they give them much treatment. I suspect that the Morgan chassis will outlast my ownership so I'm not too worried.
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
I also use Galvafroid then Waxoil on assembly.
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
I recall thinking the same when the Wheeler Dealers episode was on.
Richard 1976 4/4 4 Seater
Posts: 37 |
Hi John, what style of bolts are you using for bolting the front wngs to the body. On 4/4 someone has used very, very long slotted flat head bolts. I intend to use Stainless Steel of the correct length, but would like to replicate the factory style
Martin R
Posts: 26,760 Likes: 425
Posts: 26,760 Likes: 425 |
This for brake reaction bars. I understood when I got them for my old +4 they are designed to shear if you crash as the front is a crumple zone. They come I assume with the bars
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
I've just ordered a set (together with a panhard rod kit) so I'd be interested in views. Well worth the investment...basically tightens everything up and feels more 'secure'. Reaction Bars not a difficult job (I just painted on some black hammerite in bare holes), Panhard rod is not difficult but getting underneath to bolt the Panhard rod is easier if you have a lift or pit (I don't and meant leaning over into the rear axle area after removing tool tray).
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 5,587 |
I've drilled a few holes in my Mog , to fit Cain's bonnet stays !
Posts: 19 |
I fitted Reaction bars to my Plus 8 when I prepared it for racing. Significant difference under heavy braking, no juddering through steering wheel. Recommend.
Was advised not to bother with aftermarket panhard rod, the effects would be minimal.
Posts: 4,896 |
Was advised not to bother with aftermarket panhard rod, the effects would be minimal. IMHO panhard rod does improve the rear end feel, and is more stable when cornering hard.
Adrian
