9 members (Montegue, gmcn, hillclimber, MJF, AlyMatt, Mark+4, TBM, Graham, G4FUJ, AndyGoff), 298 guests, and 82 robots.
Sagging Hood
Topics49,858
Posts837,463
#320128 19/11/15 09:59 AM
E
E
On my 69 Morgan the aluminium castings which support the brake and clutch pedal shaft are bolted through the front vertical face of the chassis. I always through they were bolted downwards through the floor/chassis or did the way they were fixed change with later cars?
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
They're bolted downwards on my '72.
1972 4/4 2 Seater
Yes bolted downwards on my 71
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
On my '70 4/4 they're bolted forward like yours.
'61 +4 DHC
'70 4/4
'80 4/4 4seater
Around about 71 is the change over year
The +8's had the vertical fixing from '68 when they were introduced.
I always thought the change over was when they changed from the forged to the fabricated pedals, but the pictures above dont prove that out
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
E
E
Thanks for all your reply's, Looking at the pedals it doesn't seem to make much difference whether they are vertical mounted or through the floor, or does it?
Land Rover Series
Defender 90 SW
Could you post a photo of yours? It's not something I've really thought about.
1972 4/4 2 Seater
E
E
The pedals are off the car at the moment and the old chassis is buried under a pile of other stuff unfortunately.
Land Rover Series
Defender 90 SW
tmg513,
Here are a few pictures of the pedal assembly on a left hand drive 65 4/4. Note that the floor panel is cut away under the pedal assembly to provide clearance.
Hope this helps.
Warren Muse
Earlysville VA USA
E
E
Thanks for posting the pictures, very helpful. It looks like you could use the later pedals which bolt through the floor rather than through the front face of the chassis if one wanted to.
Land Rover Series
Defender 90 SW
