6 members (Mike K., Plus Four Guy, uvk33n, Haggispeed, Carbuilder, gomog), 202 guests, and 110 robots.
+8Rich 74
Luddite 50
Hacked email account
by +8Rich - 08/09/26 01:47 PM
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Topics49,888
Posts837,881
Page 62 of 94 1 2 60 61 62 63 64 93 94
RedThree #325556 12/12/15 10:05 AM
SBM Offline
Originally Posted By RedThree
Originally Posted By TimG
I was advised by my mechanic to switch on the ignition till the fuel pump stops whining, switch off then repeat twice & start engine. This does help on mine.
+1 on this, it really does work. I fired mine up on Thursday for the first time in almost four weeks; it started immediately on the button after doing this fuel pump cycling three time and that's in an unheated garage without a battery tender.
I'm going to try this. The starter never fails, nor has it ever failed to start, it just gives that queasy feeling that you're on borrowed time on occasions..!!
Q8morgan #325926 14/12/15 03:28 AM
Q
Q
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpspcowierv.jpeg.html][/url]][/url]
Q8morgan #325927 14/12/15 03:51 AM
Very cool, Q8 ! shades
thumbs cheers
2013 M3W # 793
'Mosquito'
Q8morgan #325930 14/12/15 04:46 AM
Nice effect
Q8morgan #326053 14/12/15 07:53 PM
Q
Q
Guys im fed up with the spark plug caps coming loose after 2hrs of driving..what are the best solutions..?
I used pliers at the end of the caps abit but no luck, they still come loose
Q8morgan #326058 14/12/15 08:06 PM
Drop of loctite ?
Crush the thread at the end of the plug very slightly so the cap screws on tightly ?
nippymog #326173 15/12/15 01:49 PM
I've read all of the issues with spark plug boot/caps coming loose on M3W's, many seem to have this issue.
There has to be something not quite right about the spark plug boot/cap being used. How many of you have ever had "other" boot/caps come loose on other vehicles, or any gas powered motor etc?
My Harleys have lots more vibration than what the S&S motor produces and the spark plug boot/cap coming loose or off is not an issue.
It's not a big deal to swap out the boot/caps with another brand. Even a Harley boot/cap would be better in my opinion as this is NOT an issue on any of the forums I participate in.
I just looked at a downloaded picture of the wire routing. It appears they are cable tied to a brace coming forward and it appears there is a loop in the wire, but just make sure that with vibration there is a large enough loop that it's never under tension.
Dan
Q8morgan #326240 15/12/15 06:21 PM
Q
Q
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsj2lrk8vf.jpeg.html][/url]][/url]
I first tightened the cap on the spark plug well & then squeezed the cap abit..i hope it doesn't screw loose anymore
Q8morgan #326304 15/12/15 11:05 PM
The boot fit on the porcelain alone should be enough to hold the boot/cap on the spark plug.
Some of mine are so tight I have to use a boot puller tool to get the plug wire off the plugs.
I used spark plugs with the screw on tip for years without any boots coming off. They also make a plug boot/cap that uses the straight bolt end without the threaded tip installed. These use wire cap inserts that slide down over the plug tip threads. I think most Japanese motorcycles use them.
If you spark plugs have the treaded tips, find the boot/cap for just the threaded plug without the tip screwed on.
Dan
Q8morgan #326571 17/12/15 04:19 PM
Q
Q
[email:][/email]
I will give it a try & get back to you
