0 members (), 269 guests, and 86 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#337591 02/02/16 12:23 PM
Hi I have no headlights on my 1995 4/4 I have been told that the fault is with the relay and they are no longer avalibale any ideas what to do
Change to a different relay? That has to be possible.
Hi Andy is it the dim dip relay that has gone ? I had a similar problem and ended up removing it , there is a thread somewhere describing this but i also had a problem with the light stalk on the column as after removing the dim dip it burnt out as it was carrying to much current on full beam. This needed replacing so ended up adding a relay in line.
Andy, can you give us more detail?
At present your fault is a trifle vague.
Do you mean no dip and no main, or just no dip.
If it's the dim-dip relay, they are removable, but depending on type may require some wires reconnecting.
You're better off without those troublesome dim-dip things anyway (says he who has still to remove his!) smile ).
Hi Graham it is just the dip beam not working Regards Andy
I've responded to your PM Andy.
'Fraid I only get on here evenings and weekends...
See if you can find my post re: removing dim-dip, or talk to Keith at BHM.
Removal is relatively simple, though you will need to re-connect two pairs of wires, depending on which dim-dip unit is fitted...
