4 members (John Winn, Graham, G4FUJ, lez, JohnHarris), 280 guests, and 104 robots.
+8Rich 78
Topics49,872
Posts837,690
Rudolf
RichB Offline OP
A few months ago we were driving along a country lane and a bit of a tree fell in the road and I had little option but to run over it – unpleasant noises from underneath shocked2 and some damage to the lower part of the radiator (bent fins) – luckily nothing major as we were a long way from home at the time. But looking at this back in the garage it seemed to me the lower part of the rad could be a bit exposed and, for me, the number plate mounting a bit high.
Been in the garage today trying to devise some protection for the lower rad and also ways to lower the number plate. Thought I'd share what I've done...
Decided to lower the number plate by about 75mm (3inches) so mounted some brackets to lower the plastic number plate mounting. Photo shows these and you can see the damage to centre of lower radiator.
Next made a simple wooden (sadly not ash) cross-member to mount on the over-rider brackets.
Using some steel mesh made a grill 500 x 250 mm and sprayed it black. Put some rubber trim around the sharp edges (same stuff as around the plastic number plate box)
This fitted neatly to mount off the bottom of the plastic number plate holder. Used 3 stainless 4mm bolts for this.
Mounted the wooden cross-member using 6 mm stainless bolts and existing holes in the over-rider supporting brackets. This also made the over-riders more sturdy and less wobbly.
Number plate holder and attached grill then mounted as shown (bolts on wooden cross-member yet to be shortened).
This (hopefully) will prevent any debris from the road being thrown up onto the radiator. It has also strengthened the number plate holder.
With the number plate also lowered the front of the car now looks like this. love
Time will tell if a good mod but I'm quite pleased with the results so far.... thumbs
+4 GDI Connaught Green, 2014
Magnolia
Rog Offline
Nice! Extra protection is a very wise precaution. I also have an under tray. The lowered number plate looks nice too
Roger
What a great job. Nice one.
Ian
Proper job! I have already lowered the number plate but hadn't thought about the mesh idea.. Thanks for sharing Richard.
That's really neat. I need to do something similar for my Mulfab rad that hangs down even more. I just need a "round tuit".
Cheers
Plenty in Yorkshire, lad.
Best Regards
Lang may yer lum reek
My over rider brackets are the other way round on both cars. That made it easy to fit an under tray using the existing four holes. It's harder the way yours are because the horizontal flanges are on the outside. Well done!
Neat work as ever.
My first car, a 1961 Morris Minor convertible, was 8214 MY.
Formerly known as Aldermog
Excellent...
Looks better, protects more. But is the wooden cross brace really strong enough to offer much protection from road debris, even if it ash...
