1 members (Alistair), 288 guests, and 99 robots.
+8Rich 86
Topics49,851
Posts837,443
PaulJ #343232 27/02/16 10:32 PM
Richard,
A fire risk?? How so??
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
E
E
Then perhaps an aluminium metal spun one would suit at phenomenal cost? spend
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
MarkB #343317 28/02/16 12:24 PM
Black Rat
Black Rat
Originally Posted By MarkB
Richard,
Cheers,
It's a joke....fire extinguisher by the rear wheel ? rofl
Keith
2013 narrow bodied + 4 Ruby.
Richard,
Cheers,
Indeed....curious as to why the extinguisher was placed there...
PaulJ #343327 28/02/16 01:14 PM
Ah! Actually I didn't see it there. It's a common practice at American shows to require the car to have a fire extinguisher. I have to assume that there were incidents of Car-B-Qs in the past.
FYI, although quite pretty, this is a metal tire cover and I have to believe was atrociously expensive to manufacture. This, and the compound curves of the back deck, led the MMC to continue the flat panel (less labor, easier to produce), as used on the back of the production Series 1 2Str, on the production version of the Series 1 DHC.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
PaulJ #343335 28/02/16 01:58 PM
I've had six mogs over twenty years three with and three without spare wheel covers, never noticed if the spare heel has deteriorated with the cover more than without.
Personally I would think that to get the best match to the upholstery/tonneau/roof material you'd need to get it done at the factory. However Sean at allon whites is an upholstery wizzard so if the car were a little older and an exact match were impossible then I'd plump for Sean to do the work. I think he'd be better value than the factory as well.
PaulJ #343337 28/02/16 02:17 PM
PaulJ Offline OP
Just a thought, seeing Marks beautiful coupe with the metal tyre cover, now that MMC have produced the 'Dome' for the back of the spareless AR+4, I wonder how difficult it would be to modify it to fit with a spare wheel in situ?
Thanks to all who have contributed, I'm still not sure though, if a wheel cover is better or not, even if it one with the centre missing so the spokes can be seen and appreciated.
PaulJ #343375 28/02/16 06:17 PM
Forget the wheel cover.
If you exchange the spare wheel (together with the standard wheel set) after 4-5 years you are safe.
I would not keep any wheels for more than 5 years as they harden and loose grip.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
PaulJ #344112 02/03/16 05:03 AM
Wow, Mark. I had forgotten how handsome that rear deck is, and the tire cover is exceptional. It would be enough to change my mind about spare tire covers, except that it would cost thousands to duplicate it. Wasn't it fabricated by a RR specialist?
1961 +4 Four seater
"Crude, but effective."
