6 members (Burgundymog, linklaw, RedThree, TBM, BHV, stumog), 283 guests, and 77 robots.
+8Rich 70
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,714
No problems with heat. No insulation either. I sometime wonder if no insulation is an advantage when it comes to engine heat. Also by running the exhaust out the inner fender I get it out fast. There is virtually no interior and what there is is sheet aluminum. The "Itsa Bitsa" is not a beauty queen. But if those carbs equaled (driveability) the performance of the Edelbrock 4 barrel, I think I would convert just for the looks of them.
Button
Seattle
Button
Probably equal if not better than your existing setup but don't over-carburate the engine; go for 40s rather than 45s.
My engine will pull from 1200 rpm without coughing and from there pulls like a train.
That looks a nice cap and really a bargain .easily worth Double
I am a bit sceptical about ceramic coating claims for heat reduction, I think they are a bit optimistic.
My thoughts are towards reduced underbonnet temperatures as the V8 creates a LOT of heat...I have OE cast iron manifolds. Not a lot of room for shielding either.
More head scratching needed I think.
I did get rid of some very light surface rust on the manifolds by scrubbing them with a Scotchpad and Pepsi....they are a decent cast iron grey now ....the Pepsi contains phosphoric acid.
I'm with you on this one; it's heat-soak from the engine that's the major problem. It was an issue with the Rover 3500 in standard spec let alone a comp spec engine. The heat from the engine, transmission tunnel and under-door area is quite considerable in summer.
Having said that, the white ceramic finish does appeal to my vain side!
As I said, I don't have heat problems. However; if it is 100F outside it is considerably hotter inside. I am amused, sometimes, with the attempts to get fresh air into the cockpit. However I have tried to do just this. On My +4-4 Str I put a 3" hole in the Bonnet, covered with a marine grill, into the foot space on the passenger side. To that installed a boat "Bilge Blower" to try and keep Mrs. Button comfortable. When it gets this hot, that the bilge blower was necessary I would look for an "Air Conditioned Motel". Heat shields over the muffler's help. The Roadsters in the U.S. have airconditioning. I almost had an air conditioning unit into the +8 Bitsa. I still have the pieces from "Vintage Air" in Texas. It was, as you call it, a bodge. Mrs. Button passed away and I abandoned the idea.
Button
Seattle
Button
Ray Offline
All this is for people that only drive their cars in the summer.
Miaow!
Best Regards
Lang may yer lum reek
That is a lovely bit of craftsmanship but I've become attached to my orange lump of plastic.
