3 members (Brian G, Jo S, PeterVD), 255 guests, and 30 robots.
John V6 69
DaveW 68
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,023
RedThree
Page 3 of 6 1 2 3 4 5 6
Mark,
Oops - I have ordered 4 from Rimmer Bros. Do I really need 8?
I have also a spare grub screw as the GoMog article indicates these are likely to fail.
Michael
Originally Posted By MarkB
The Rimmer Brothers part number for the bushing is as follows
UKC854POLY BUSH 5SP.REMOTE 4.08 48.96
You will need 8 of them.
Cheers,
I have ordered 4 of the UKC854POLY bushes - I did ask Rimmer Bros if that was the right number. Looks like I should reorder 4 more. Michael
Well, there are four mounting points, actually two pair of mounting points, with two bushes per point (both sides.) It could be possible that there are several that are not bad and could be reused. The older material used (rubber?) however wears faster than the newer Poly bushes.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Cheers,
Mark,
I really don't look forward to taking the floor up again so I will renew all 8.
Many thanks
Michael
A grub screw?? I have never needed one nor actually seen one not in situ. If you could, a pic would be great.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
I had problems with the 3. gear on my +4 2000 mod. The bushes was OK but the problem was the housing of the ball inside the remote unit, see attached picture. I did send the remote unit to Brands Hatch Morgan for service. I got exelent advice by phone from Keith at BHM seaching and fixing the problem.
Ragnar
2000 mod +4
Cheers,
According to the GoMog guide to +8 (1977-2004) and +4 (Rover versions 1985-2002) Gearbox Remote problem,allen screws there seems to be 4 issues: the rubber bushes, the grub screw, the tensioning cup and adjusting the remote.
In the earlier remotes it appears that a grub screw was used to hold the remote yoke to the remote shaft. In the photo posted by Ragnar he seems to have an upgraded screw to hold the yoke in his remote to his remote shaft. As his car is more recent than mine (2000) I assume he also has a later version of remote. I cannot send you a photo of mine grub screw as the car is in France but I will take a photo when I strip the remote down in around 10 days time. If it is still tight I will not disturb it but I want to ensure it does not let me down at some time in the future.
I hope this is helpful.
Michael
Hi Michael,
Personally and for what it's worth, I would avoid stripping down the remote (it's possible that I've misinterpreted your intentions) as resetting the detent tensions for the 3rd/4th bias and reverse lock-out can involve a fair bit of fiddling and trial and error to get it right.
Also, I've never heard of the grub screw coming loose so your problem is unlikely to be due to a fault here.
Simply clean the remote as undoubtedly it will be covered in years of accumulated crud.
Incidentally, your car should be fitted with an LT77 gearbox and therefore the remote will be fitted with a plate held with two bolts and springs to provide the reverse lock-out.
Enjoy your dirty weekend!
Hi David,
All parts have now arrived.
The remote and gearbox should not be too dirty as I cleaned them when I overhauled the entire rear axle a couple of years ago.
I am therefore hoping for only a couple of dirty days in the south of France.
Got to be good - will keep you all informed.
Thanks again.
Michael
I do hope this is the fix. The LT77S was known for weak synchro on 2nd...
Admittedly, this was mainly on the Discovery.
'09 Gen2 MINI Cooper ragtop
