4 members (Willowgreen320, Topline123, Stephen888, nick w), 234 guests, and 71 robots.
+8Rich 78
Topics49,871
Posts837,679
Rudolf
#353837 07/04/16 09:50 AM
Hi, I have a 1965 Morgan plus4 I'm having a very hard time removing the rubber fill hose for the fuel tank any suggestions thanks
Are you replacing or just removing?
If replacing I'd slit it with a blade.
The hose can get almost welded to the tank/filler pipes after a long time. If you can get the collet on the back of the fuel filler undone a little, this will allow you to turn the filler cap in the back panel and may help release the hose. Otherwise it will probably have to be cut in the middle and prised of each end. Once you have the clips off a little WD40 in the junction behind the filler cap may help also.
This is for the flip up type filler on a two seater. Hope it helps!
If you are removing the filler pipe because it has perished, please see this link:
http://www.talkmorgan.com/ubbthreads.php/topics/286413/Silicone_fuel_filler_pipe#Post286413
Posting Desperado
Posting Desperado
When you replace it the new one has to be lined with a certain kind of rubber that is not by the new petrol. Replaced mine 2 year ago.
This is new to Me. I have had problems with gas hose. Cost Me an extra day in New Orleans to get it sorted. Ethanol! I now change all the gas hose every two years.
Yes I would slit the old hose to remove it.
Button
Seattle
Button
can these be purchased at any auto parts store then cut to size
If IRRC for a 65 +4 they are 2 inch internal but it's not straight as you can do doubt tell from the old one. There is about a thirty degree bend about two thirds of the way down. Tall order for a local parts store I would think especially in the correct material.
I spoke with Morgan spares they say the new hose is 1/8 in smaller and difficult to get on, I'm wondering if they make it in flex hose stainless
You might be able to get this to fit with a bit of modification. http://www.autosiliconehoses.com/silicone-fuel-oil-fluoro-45-degree-elbow-hose-choose-size.html Seems to be available with a 48 or 51mm internal. Not sure of the original length which you can check but it looks about right. Ordinary silicone hose is not suitable for fuel/petrol/oil.
