7 members (PPD, B3MOG, James B W, Scrambledsignals, t50, Ulfulf, TBM), 363 guests, and 40 robots.
Adam12 70
+8Rich 69
John V6 52
9,215 Registered Users
Latest toy…
by Grumpy2 - 03/08/25 08:06 AM
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,376
Posts813,550
Members9,215
#354231 08/04/16 01:21 PM
MGDave Offline OP
Getting close to changing the oil, I've bought Castrol GTX and now I'm wondering what oil filter should I use, I don't want to assume that the old one is correct.
Recommendations would be appreciated.
Dave
98 +8 Corsa Red
74 MGB Red
Dave,
I've always found the right parts on here,
Cheap and quick delivery.
How this helps.
http://www.carparts4less.co.uk/car-parts
Oops sorry didn't spot that you were in Canada.
Engine size would help. Can advise then
Dave, I have a three page cross reference list with every filter that will fit. If you want it send me an email. Series1@cfl.rr.com
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
MGDave Offline OP
I should have noted the engine size. It's a 4 litre.
Thanks to all for the help.
Cheers
Dave
98 +8 Corsa Red
74 MGB Red
Hi Dave,
I use either of these but I guess many others will do the job.
MANN W930/20 or BOSCH H24W03.
Don't forget to near enough fill the filter before you screw it on.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
Get everything ready before you drain the oil. Pre-fill the new filter, drain sump and refit plug and filter, fill with oil without a coffee break! A quirk of the engine is that sometimes the oil pump drains too much and will need priming. See Gomog website. I have the 4l engine and never had issues with refilling but a sensible no delay change is unlikely to cause a problem.
In Gomog go to Workshop section then Plus8 specific section for details.
I have a 2003 4 liter. The Rover Filter is ERR-3340. I am using the equivalent Wix 51068. NAPA is 1068. NAPA lists the usage as Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90), so it is pretty common. My auto parts store stocks them.
As recommended above, I pre-fill the filter to avoid losing the prime in the oil pump.
Dave White
2003 Plus 8
This is the UK reference site for K&N filters - undoubtedly the best.You will need to search under Landrover 4.0 ltr V8 engine.
http://www.knfilters.co.uk/search/appsea...amp;engine=4.0L
